Question about Kohler K-3384-2 San Raphael Elongated Toilet With French Curve Quiet-Close
Kohler Toilet seat bolts stuck
Toilet seat bolts are rusting and plastic caps broken. When I tried to remove the bolts they were stuck and would not turn.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
If the bolts are plastic or metal you will need to cut them off and install new ones from new seat or bolt kit there is no easy trick its just an easy cut them off or you could try some wd-40 or nutbuster.
Posted on Nov 30, 2014
  • 51 Answers
SOURCE: broken bolt on toilet seat
your new seat will have bolts and nuts with it.
Posted on Jan 12, 2009
bozcro
  • 867 Answers
SOURCE: Can not remove toilet seat from Kohler Rialto
to access the nut remove the tank lid, then go down and forward, its there.
Posted on Jul 03, 2009
joecoolvette
  • 5660 Answers
SOURCE: My toilet is a kohler low profile. There is not a
Hacked off the old seat? You mean the closet flange that connects to the sewer pipe?
That's the part that has the bolts. They go up through the toilet base.
If you have just a straight sewer pipe now, you can connect a new closet flange to it.
1.Hardware stores sell a rubber sleeve. This sleeve fits over the cast iron, or copper, or plastic PVC pipe, and the new closet flange has a stem that fits down in the sleeve. There are two large hose clamps, that come with this rubber sleeve.
The rubber sleeve is an adapter. It adapts the 4 inch sewer pipe, down to the 3 inch stem on the closet flange. (Toilets are known as a 'Water Closet', hence the flange that the toilet bolts to, is a 'Closet Flange')
Whatever size of rubber sleeve you need to adapt two pipes together, they have it.
The new closet flange is made of PVC plastic.
(Poly Vinyl Chloride)
The flange itself is about 1/2 inch thick, and has provisions for bolts. (Use Toilet Bolts, and nuts)
Be sure the closet flange sits flush to the floor. The 1/2 inch thick rim of the flange, sits on top of the floor. The flange is then screwed to the floor with countersink head screws. The slots allow the bolts to just slip in.
IF, the flange Does Not sit level on the floor, and the area for the toilet base is not level, you need to make a flat, level surface!
Do Not half step this, or you'll have a toilet leak from now until the time you fix the floor!
Would appreciate it if you would rate my solution. If you have additional questions, state them by clicking on Additional Comments.
Posted on Jul 17, 2009
  • 3 Answers
SOURCE: What is the best way to remove stuck toilet anchors
try rotating the entire toilet counter clockwise so the bolts are in the insert slot of the toilet flange and rotate the nut and the bolt head should line up and pop free of flange.
Posted on Oct 31, 2009
  • 3600 Answers
SOURCE: How do I replace the toilet seat on a Kohler
I repaied one of these laast week and it had the Plastic nuts in between the webbing on the seat where the lid connects I believe You remove the plastic cap with a knife and use a flat tip screw driver to remove the screws and replace the seat.
Posted on Jun 01, 2010
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
Aug 29, 2013 | Kohler 3386-6 Rialto Skylight Round Front...
Kohler cimarron broken seat, replacement parts don't work 2x's
No do not use metal bolt and nut as this can crack the toilet. Just go to Lowes or Home Depot and buy 2 plastic bolts , 2 plastic wing nuts, and 2 plastic washers. Install with seat through toilet holes and tighten by hand until tight. I then use pliers to tight just a turn tighter and the seat should be center as you tightened one side, then the other, and back again until tight.
Mar 17, 2013 | Kohler Cimarron Comfort Height 2-Piece 1.6...
Stuck kohler toilet seat
most modern toilet seats are removed by opening plastic tabs on the upper rear of the seat and turning the screws counter clockwise while holding the retaining nuts underneath the bowl.there has to be access and if not ,you could drill them out from the top using a small drill bit and slowly working your way up to bigger bits till the heads of the bolts are removed.
Nov 21, 2011 | Kohler Home
The Rialto toilet makes it very difficult to replace the seat as you cannot access the wing nuts which in a moment of engineering genius you put inside the bowl I have already purchased a French seat to...
You should be able to remove the tank lid, reach into the cistern and find submerged at the bottom towards the front of the toilet the plastic wing nuts, hold onto these while tightening the plastic bolt from the top.
I have a Kohler toilet with a similar design, not sure if it is this exact model but they look very similar so I hope this works for you.
Apr 18, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
Jun 01, 2010 | Kohler 3386-6 Rialto Skylight Round Front...
Get seat of Kohler K-3386
Roberta3fan could be giving bad advice based on experience with other toilets. This does not seem to be an option for this toilet design. I am in a similar situation and it appears that the nut (and it is a metal bolt) is not what you would expect. Here is a picture of the anchor kit for this toilet seat: http://www.plumbingsupply.com/images/kohler-anchorkit-84999.jpg I am going to assume that the sleave that should be engaging the bolt is cross threaded and try to grab it with a pair of vice grips. I'll let you know if it works.
Jan 09, 2010 | Kohler K-3386-0 Rialto one-piece...
Oct 30, 2009 | Kohler K-3384-2 San Raphael Elongated...
Kohler lowboy toilet seat does not have bolts underneath
I have the same low boy where the bolts are inside the hollow body of the toilet. I called Kohler customer service and was told to use brute force to yank the toilet seat out. My husband suggested using a saw to cut the bolt but he hasn't done it yet. He wants to replace all our Kohler low boys which constantly leak becos of poor design of handle and flapper. The handle pulls the flapper slightly to the side when you flush. And the flapper lip being a tiny bit too small, if it doesn't sit just right, the toilet leaks. We've replaced one already with a Toto and love it. Too bad that Kohler isn't trying to fix the problem as I see many many online posts with the same problem and recommendation to replace the Kohler with Toto or somethng else.
Jul 29, 2009 | Kohler - Toilet Seat - Moondance -...
Broken bolt on toilet seat
Jan 11, 2009 | Kohler - Toilet - One-piece - Santa Rosa -...
How do you tighten bolts on Kohler toilet seats the bolt has a plastic cap?
The caps are at the back of the toilet seat. Just under the cap cover are the bolts. You will need a meduim sized flat screw driver. Hold the nut on the bottom and use the screw driver to tighten.
The covers pry up with a small screw driver IF they are square.
If they are more circular with ears they rotate counter clockwise about 30 degrees, Then lift the lid off.
Please rate this response and Good Luck, Phil
Dec 29, 2008 | Home
Kohler K-3384-2 San Raphael Elongated Toilet With French Curve Quiet-Close Logo
123 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
