Question about Orbit Trvlng Tractor Sprinkler
How to make it go forward - Orbit Trvlng Tractor Sprinkler
I forwarded my cell phone calls to my house phone. I cannot deactivate call forwarding. I have a Samsung S7
  • 1.From the home screen, tap Phone
  • 2.Tap More
  • 3.Tap Settings
  • 4.Tap More Settings
  • 5.Tap Call Forwarding
  • 6.Tap Always Forward
  • 7.Enter the number you would like your calls forwarded to and then tap Enable
  • 8.To disable call forwarding, swipe down from the top of the screen
  • 9.Tap the Call Forwarding notification
  • 10.Tap Always Forward
  • 11.Tap Disable
Samsung Galaxy S5 How to Setup Call Forwarding
Feb 11, 2017 | Samsung Cell Phones
How can I setup forward call to my cel from VTECH CS6649-2
Call forwarding typically can redirect incoming calls to any other domestic telephone number, but the owner of the forwarded line must pay any toll charges for forwarded calls. Call forwarding is often enabled by dialing *72 followed by the telephone number to which calls should be forwarded. Once someone answers, call forwarding is in effect. If no one answers or the line is busy, the dialing sequence must be repeated to effect call forwarding. Call forwarding is disabled by dialing *73. This feature requires a subscription from the telephone company. Also available in some areas is Remote Access to call forwarding, which permit the control over call forwarding from telephones other than the subscriber's telephone. VOIP and cable telephone systems also often allow call forwarding to be set up and directed via their web portals. https://en.wikipedia.org/wiki/Call_forwarding
Jul 14, 2015 | Vtech CS6649-2 Digital Answering System,...
X box cheat codes ( mortal combat deception)
Ashrah's First Fatality Down, Down, Up, Up, Y (close) Ashrah's Second Fatality Forward, Down, Forward, Down, Y (sweep) Baraka's First Fatality Forward, Up, Down, Y (close) Baraka's Second Fatality Forward, Down, Back, Forward, Y (sweep) Bo Rai Cho's First Fatality Down, Up, Forward, Forward, Y (sweep) Bo Rai Cho's Second Fatality Up, Back, Forward, A (sweep) Dairou's First Fatality Down, Up, Back, Back, X (sweep) Dairou's Second Fatality Down, Down, Back, A (close) Darrius's First Fatality Up, Down, Back, Forward, A (sweep) Darrius's Second Fatality Down, Forward, Forward, Up, X (close) Ermac's First Fatality Down, Back, Back, Down, A (sweep) Ermac's Second Fatality Back, Down, Back, Down, B (sweep) Havik's First Fatality Down, Forward, Forward, Up, B (close) Havik's Second Fatality Forward, Forward, Forward, Back, Y (sweep) Hotaru's First Fatality Forward, Up, Back, Down, X (sweep) Hotaru's Second Fatality Down, Forward, Back, Forward, Y (close) Jade's First Fatality Back, Forward, Up, Forward, X (sweep) Jade's Second Fatality Back, Forward, Forward, Forward, Y (close) Kabal's First Fatality Forward, Up, Up, Up, A (close) Kabal's Second Fatality Up, Up, Down, Down, Y (close) Kenshi's First Fatality Forward, Forward, Back, Back, Y (sweep) Kenshi's Second Fatality Up, Forward, Back, Forward, Y (sweep) Kira's First Fatality Back, Forward, Forward, Back, B (far) Kira's Second Fatality Up, Forward, Down, Back, A (sweep) Kobra's First Fatality Down, Back, Forward, Down, B (close) Kobra's Second Fatality Forward, Back, Forward, Forward, Y (close) Li Mei's First Ftality Forward, Forward, Forward, Forward, X (sweep) Li Mei's Second Fatality Up, Back, Forward, Forward, B (sweep) Liu Kang's First Fatality Back, Back, Back, Forward, Y (sweep) Liu Kang's Second Fatality Forward, Forward, Up, Up, A (sweep) Mileena's First Fatality Forward, Forward, Down, Down, X (sweep) Mileena's Second Fatality Up, Up, Forward, Forward, A (far) Nightwolf's First Fatality Back, Forward, Back, Forward, X (far) Nightwolf's Second Fatality Down, Forward, Down, Up, Y (sweep) Noob Saibot & Smoke's First Fatality Back, Forward, Back, Forward, B (must be noob) (sweep) Noob Saibot & Smoke's Second Fatality Up, Down, Down, Forward, Y (must be smoke) (sweep) Raiden's First Fatality Back, Down, Forward, Down, X (sweep) Raiden's Second Fatality Up, Down, Forward, Forward, X (far) Scorpion's First Fatality Forward, Down, Forward, Forward, X (sweep) Scorpion's Second Fatality Forward, Back, Forward, Back, X (close) Shujinko's First Fatality Up, Down, Down, Forward, A (close) Shujinko's Second Fatality Back, Up, Forward, Forward, X (close) Sindel's First Fatality Back, Forward, Forward, Back, X (sweep) Sindel's Second Fatality Up, Up, Back, Forward, A (sweep) Sub-Zero's First Fatality Forward, Back,. Down, Forward, Y (close) Sub-Zero's Second Fatality Back, Down, Forward, Down, X (sweep) Tanya's First Fatality Forward, Down, Down, Down, X (close) Tanya's Second Fatality Up, Back, Forward, Up, A (close) Contributed By: flump.
10
Hari Kiris
After an opponent has beaten you and the anouncer yells "Finish Him!" it is time to input a Hari Kiri. Hari Kiris require no set distance unlike fatalities. To perform one simply put in the code while your character is dazed after losing a battle.
Effect Code Ashrah's Hari Kiri Up, Down, Up, Up, Y Baraka's Hari Kiri Down, Back, Up, Back, B Bo Rai Cho's Hari Kiri Back, Back, Forward, Forward, Y Dairou's Hari Kiri Back, Back, Back, Down, X Darrius's Hari Kiri Back, Forward, Forward, Y Ermac's Hari Kiri Down, Up, Up, Down, A Havik's Hari Kiri Forward, Up, Up, Up, Y Hotaru's Hari Kiri Up, Back, Back, Back, Y Jade's Hari Kiri Forward, Forward, Forward, Back, Y Kabal's Hari Kiri Forward, Up, Up, Down, Y Kenshi's Hari Kiri Down, Back, Back, Forward, B Kira's Hari Kiri Forward, Back, Up, Back, A Kobra's Hari Kiri Up, Up, Back, Back, Y Li Mei's Hari Kiri Up, Down, Up, Down, A Liu Kang's Hari Kiri Down, Down, Down, Up, A Mileena's Hari Kiri Back, Down, Forward, Back, X Nightwolf's Hari Kiri Up, Up, Up, Up, A Noob Saibot & Smoke's Hari Kiri Down, Up, Up, Down, B Raiden's Hari Kiri Forward, Up, Up, Back, X Scorpion's Hari Kiri Down, Down, Up, Back, X Shujinko's Hari Kiri Down, Back, Down, Back, A Sindel's Hari Kiri Forward, Up, Up, Down, B Sub-Zero's Hari Kiri Down, Up, Down, Up, Y Tanya's Hari Kiri Down, Down, Forward, Up, A
Jul 30, 2014 | Video Game Consoles & Games
What do you mean by forwarding on conditional on?
Forwarding on conditional, means that calls can be forwarded to a different number (or voicemail) on certain conditions.
These could be, unanswered, unobtainable or busy.
Normally you would have this set to forward to voicemail if you are unreachable, or unanswered.
But you can forward ALL calls to a different number if you wish.
Please note that different phone providers can charge for this feature.
i.e. forwarding a call to your home number, they may charge you for forwarding.
May 12, 2014 | Cell Phones
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
May 02, 2014 | Nokia Asha 311 Mobile Phone - Unlocked Red
How do I forward yahoo email automatically to another email address
You can obviously forward your emails to the other account; all you have to do is enabling of the forwarding message settings in your account. All you have to do is "click on settings":
If you are using gmail you will see "forwarding imap/pop or forwarding tab"; click on it you will have to enter the yahoo email address on which you want to forward the mails and then a verification code link will be sent to that email by clicking on which you will be able to forward the mails to yahoo.
If its outlook, you have to go for the "email forwarding tab" and enter the yahoo mail address on which you have to forward your mails and then a verification code link will be sent to that email by clicking on which you will be able to forward the mails to yahoo.
You also can set up filters to forward messages that meet specific criteria. You can create 20 filters that forward to other addresses and can also maximize your filtered forwarding by combining filters that send to the same address.
Apr 20, 2013 | Yahoo Mail
I want to forward my faxes from my Panasonic machine to another # temporarily.. is this possible and how?
Fax forwarding You might want to set up fax forwarding if you are going on a trip, but still want to receive your faxes while you are away. There are three fax forwarding settings:
  • Off (default)
  • Forward-When your All-In-One receives a fax, it holds it in memory and then sends it to the fax number that you designate.
  • Print and Forward-Your All-In-One forwards the fax to the designated fax number and prints the fax.
To set up fax forwarding:
  1. On the control panel, press Fax.
  2. Press Options until Fax Forward appears, and then press Select.
  3. Use the arrow buttons to scroll to the option that you prefer (Fax Forward or Print and Forward) appears, and then press Select.
  4. Enter the number that you want to forward the fax to, and then press Select.
Fwd now appears on the bottom left corner of the display.
Dec 16, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Nortel T7316E Call Forwarding - Outside Line
The Nortel call forwarding (feature 4) is for forwarding the ringing and intercom from one extension to another.ex. if you were going to be working in the conference rm. instead of at your desk,with the forward on to the conference rm. extension, the calls you get at your desk will transfer to the conference rm. phone. Call forwarding through your service provider is done by accessing the telephone line you wish to forward, dial *72 (you should get dialtone reordered)and dial the telephone number to where you want the calls to be forwarded to. the party on where your forwarding the line to has to answer the line for the forward to take place. to remove call forwarding , access the line you have the forward on and dial * 73, you should recieve a stuttered dialtone for confirmation that the service is off
Dec 07, 2009 | Nortel Norstar 16-Line PBX Speakerphone
How do I forward call on my blackberry?
Open BlackBerry Call Forwarding Options
To access your BlackBerry call forwarding options screen, click the green Send key and then open the menu options by clicking the BlackBerry Menu key. Scroll down and select Options.
You'll then be presented with a list of your BlackBerry's Phone Options, which include Call Forwarding. Click on this option and wait a few seconds for the call forwarding screen to populate.
Enter a New BlackBerry Call Forwarding Phone Number
Before you can forward incoming calls via BlackBerry, you first need to enter the number you want calls to be forwarded to.
On the main Call Forwarding options screen, click your BlackBerry Menu key and choose New Number. A dialogue box will then appear asking for the number to which your calls will be forwarded. Type in the 10 digits and click the trackball to save the number.
If you mistyped the new call forwarding number and you need to correct it you can click the BlackBerry Menu key on the main call forwarding screen, choose Edit Number, scroll to the number you wish to modify, click the trackball again and choose Edit from the available options. From there, you can make your desired corrections. To save the changes, simply click the trackball one more time. You'll then be returned to the Edit Forwarding Numbers screen. You can reach the main Call Forwarding option screen by clicking the BlackBerry Escape key once.
Enable BlackBerry Call Forwarding, Tweak Settings
On the main BlackBerry Call Forwarding screen, you have two options for call forwarding: 1) Forward All CallsForward Unanswered Calls. Below the latter option, you have three more choices: A) If Busy; B) If No Reply; and C) If Not Reachable.
By default, your device is set to Forward Unanswered Calls to your carrier's voice mail box in all instances.
BlackBerry Forward Unanswered Call Options
Forwarding every call that comes in to your device is simple; you just fill in the circle next to Forward All Calls and then specify the number to which you wish to direct calls from the corresponding drop-down menu. To save any changes you make, click the BlackBerry Escape key and confirm the changes when prompted.
Forwarding calls in specific situations is a bit different, but it's no more difficult. The first thing you want to do is ensure that the circle next to Forward Unanswered Calls is filled in. (Again, this circle will be filled by default unless you modified your settings.)
To forward only the calls that come in while you're already on the line, click on the If Busy option to open the drop-down menu and then choose the number to which you want to forward your BlackBerry calls. If that's the only call forwarding option you wish to modify, click the BlackBerry Escape key and confirm the change when prompted.
If you want to forward calls that come in while you're, say, in another room and away from the phone, change the number associated with the If No Reply option and save your changes.
If you want to receive calls when your BlackBerry is turned off or you're otherwise unreachable, modify the number settings next to the If Not Reachable option and again save your changes.
When BlackBerry call forwarding is enabled, you'll see a small icon, which looks very much like the missed call icon, appear on your BlackBerry home screen.
Finally, if you wish to return to your device's default settings, simply fill in the circle next to the Forward Unanswered Calls option and set the number for all three options (If Busy, If No Reply and If Not Reachable) to your wireless carrier's voice mail digits.
May 11, 2009 | Google Android
Orbit Trvlng Tractor Sprinkler Logo
46 people viewed this question
Top Orbit Garden Experts
richie46
woodzowl307
Are you an Orbit Garden Expert? Answer questions, earn points and help others
