Question about Philips Magnavox Learning Universal Remote
Ive got a magnavox 00M146SB-AA01 big screen tv vcr remote control
How do you use it to toggle between two channels?
Didn't solve it, but it's not that important to have to pay for it. Thanks anyway.
Posted on Jun 18, 2009
Need code for magnavox DVD player for Tekpartneruniversal remote D
[PDF]Tek Partner Universal Big Button Remote Control Users ...
https://www.activeforever.com/content/manuals/A18037-Manual.pdf
Tek Partner Universal Remote Control. User's Manual .... On the remote control, press and hold the MODE button (TV, VCR, DVD or. CBL/SAT) until the indicator ...
Support - Big Button Remotes
Dec 07, 2015 | Magnavox Televison & Video
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
Magnavox 20MC4304 20" TV/DVD/VCR Combo Remote:
A universal remote should solve your problem. You should be able to find one on ebay. You may even be able to find one for your particular TV on ebay as well.
Dec 03, 2017 | Magnavox NE206UD TV/VCR/DVD Combo Remote...
I have an universal Philips Magnavox remote don't know the model # but I just need to know how to search for the codes. I can't remember how.
These are generic code search instructions for Phillips/Magnavox
Programing with Code Search
1. Manually turn on (TV,VCR,etc.) to be controlled.
2. Press and hold Code Search button until red indicator stays on.
Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.).
The red indicator blinks, then stays lit.
4. Press the Channel Up button repeatedly ( up to 300 times )
until the device to be controlled changes channel.
The red indicator blinks, then stays lit. If you accidentally
overshoot the code required, press the Channel Down button to
backtrack through the library until the device changes channel.
Pressing Channel Up changes direction to forward again.
Press and release the Mute button to install the code.
If the device you are installing does not have a Channel Up button
use Play(VCR only) or Power, on all other devices.
Jan 03, 2009 | Philips Magnavox Learning Universal Remote
Remote control code for Magnavox 15MF605T/17
oif the codes in setup don't work for the direct tv remote, here is a code list at the end of the post
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Need VCR codes for Magnavox Universal remote model CL034
Nov 26, 2008 | Philips Magnavox Learning Universal Remote
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
Philips Universal Remote SRU2103WM/17
Try this:
Hope this helps :)
Jun 02, 2008 | Philips Magnavox Learning Universal Remote
Remote code
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Sep 07, 2007 | Philips Magnavox Learning Universal Remote
Philips Magnavox Learning Universal Remote Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
