Question about MagLite 3 Cell D Blue Flashlight S3D116
Changing led bulb in maglight 3d - MagLite 3 Cell D Blue Flashlight S3D116
How do you change the batteries in a 3D cell Great Lite flashlight
You just unscrew the cap at the end of the flashlight. You will also find a spare bulb in the cap.
Surprised you would buy one of these when LED flashlights are 5 times brighter and the LED lasts forever. Take a look at this one.
https://www.amazon.com/dp/B01JZ6BKCQ?psc=1
https://www.steveswholesaletools.com/products/greatlite-3d-cell-flashlight%7CL58%7CC68%7C05-32024.html
Great Lite GREATLITE 3D CELL FLASHLIGHT
Sep 13, 2016 | Electrical Supplies
Repair for Innova GT 3 led, 3 AA battery flashlight.
Before doing serious damage, check for a poor ground to the case. I have worked on a couple of these and some of the manufacturers seem to believe a solder connection to an anodized aluminum case is going to work. Use a tool with a sharp point to scratch through the anodized layer to expose a clean metal ground. You may have to repeat this from time to time as the light fails.
Aug 26, 2016 | Camping, Backpacking & Hiking
Can I buy a newer 3d cell led maglight and put the 6dcell body from my old maglight on it?
Yes, provided the higher voltage is compatible with the other unit.
I=voltage/resistance. If the higher voltage increases the current past the limitations of your unit, you may burn it out prematurely.
Feb 18, 2016 | Camping, Backpacking & Hiking
I need the small tool to be able to get into the outer cover( the black button )to be able to change the bulb. where I can replace the bulb.
I believe you have to take the rubber cover over the button off, then push on the edges of the button, it's attached to the light assembly so you can pull it out, call Maglite tech, they'll help. Good luck.
Mar 30, 2015 | Other MAG-3D-LED - Maglite 3 D-Cell LED...
Maglight fades to off after 5 seconds
Has this just happened after working ok? Is this a new maglight? Have you tried brand new batteries? Have you checked metal contacts to the batteries?
Dec 19, 2014 | Rothco Maglight 3-D Cell LED Flashlight -...
Can a large maglite be repaired or parts replaced when the batteries corrode in the chamber?
Try spraying WD40 or similar penetrant on battery terminals and cleaning with wire wool! You might be lucky!
Sep 15, 2014 | Rothco Maglight 3-D Cell LED Flashlight
Where do I send my Maglite for repair?
hello
the warranty details and the address are here Albert. Good choice in flashlights, but you may wish to look at LED units. The technology has moved on, and Cree LEDs are incredibly bright for the size. Some comapnies make LED modules for Maglight. I have one.
http://www.maglite.com/repaircenters.asp Repair Centers Mag Instrument Inc Manufacturer of the Maglite Flashlight
Jul 29, 2014 | Mag Instrument AAA Mini Maglite...
How do you replace the LED bulb in a AA cell maglight flashlight
question is in TV section--answer would be contact Maglight to see if the part is even available and if not buy another flashlight.
May 04, 2012 | Televison & Video
The last battery in my 3-cell Maglight (closest to the end, farthest from the bulb) has leaked acid out inside the tube /handle and caused the battery to get stuck, I can't get it out to clean it up and...
Unscrew the lens and remove the bulb, then get a small disposable container and fill it about an inch full with WD-40, or a similar de-seizing fluid. submerge the stuck end in the fluid for a few minutes and it should come off without issue. Make sure to clean the tube completely before replacing the bulb, lens, and batteries.
Feb 28, 2011 | MagLite Mag-Lite& Flashlight
How do i remove the led bulb in my 3D cell Mag-lite dl
http://www.takeitapart.net/archives/mag-lite-2d/
May 14, 2010 | Camping, Backpacking & Hiking
MagLite 3 Cell D Blue Flashlight S3D116 Logo
112 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
