Question about Microwave Ovens
Kenmore Elite washer model 40512900 displays lE
Hi, I have a Kenmore Elite 790.4102 that has CA in the display and doesn't allow the oven keys to work or display the time. Can anyone help me to see if it is a easy fix?
You would need the full model from the tag, and it will be one of these:
http://www.searspartsdirect.com/model/search.html?q=790.4102
You can download manuals form that page and look up any needed parts.
Feel free to contact me via microwavecontrol.com with your full model number and detailed symptoms if you need more help.
Aug 21, 2016 | Kenmore Microwave Ovens
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Kenmore elite model #665.61683101, has no power, plug works but microwave has no display, is there a fuse in this model?
There is a line fuse for this oven. Remove the cabinet and the fuse should be close to the line cord. Replacement fuses should be found at your local appliance supply house.
Apr 19, 2011 | Kenmore 62622 Microwave Oven
The display screen has gone blank on my 721.80802400 Kenmore Elite. Of course since it is dial operated, this means we have basically lost all functionality other than adding time in 30sec increments. ...
The main displays are not fused, sorry, Also the display itself is not wired to the baord. It is either soldered on or has a conductive rubber pad under it to bring power to the crystal. Get your model number and either call sears or another parts company for a price and availability on the main circuit board.
Sep 29, 2017 | Kenmore 80809 Microwave Oven
Hi, i own a kenmore elite speedcook oven model 363.63692301, ever since my wife used the convection speedcook oven and had the heat setting set to the maximum temp of 450 degrees which the oven should...
I have had issues with my Kenmore Elite conv oven too. I have had several service calls and found out that the TCU (thermal cooling unit) sensor was not working. This allows the oven to cool down so it doesnt overheat the sensors in the display. I actually had to have the oven replaced after 4 months of use. I am currently waiting for a technician to review the replacement oven for the same issue. I spent $7k on all new Elite appliances and will never purchase Kenmore appliances again. Good luck
Nov 30, 2010 | Kenmore Microwave Ovens
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
Kenmore Elite microwave Combi funtion not working
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 29, 2009 | Kenmore 62622 Microwave Oven
Display needs to be replaced on a kenmore elite microwave
Try managemyhome.com. I have a Kenmore Elite convection microwave and found the manual.
Jul 03, 2009 | Sharp R-1750 Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
