Question about Frigidaire FRT17B3A Top Freezer Refrigerator
Water is leaking from somewhere onto the floor
  • Frigidaire Master
  • 528 Answers
The drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Posted on Jan 02, 2010
Frigidaire refrigerator with ice maker leaks water
It sounds like your ice maker is leaking.
If you are able, try opening up the ice maker for a visual inspection.
just remember to unplug first.
Apparently there is a leak somewhere.
Sometimes ice makers will over flow if the float gets stuck or a connection has come loose.
If you cannot work on it yourself, then I suggest looking up a service technician on the Fixya website.
Apr 22, 2008 | Refrigerators
Leaks onto the floor
With or without a load in the dishwasher, start the wash cycle and watch the whole thing. Inspect around the door to see if water is seeping through the seal. If no water is leaking around the door, then there may be a cracked hose line somewhere else.
Apr 12, 2012 | Jenn-Air 24 in. JDB1100AWS Built-in...
Washer and dryer stackable unit. water is leaking from somewhere onto the floor causing floor swelling. what could be the problem?
Thanks for choosing FixYa and welcome to the sight. You need to make sure your drain hose is not clogged up or your hoses are not damaged. You need to check the water pump also. It may be clogged or leaking from the pump area. Make sure the tub is not cracked or damaged, causing water to run out. Your best bet is starting the washer while you are viewing the hoses and the pump. You should be able to find the leak this way.
Apr 22, 2011 | GE WSM2420T Top Load Stacked Washer /...
Water leaks into bottom of freezer. it re freezes, and then also
hi there,
there a leak somewhere in there. there is no way you can fix this yourself, call the repairman or LG's customer service.
Jun 07, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
It leaks water onto the floor.
Where is the water coming from? unless you have a leaking ice maker fitting on the back or somewhere else, the most likely cause would be a stopped up defrost drain. check inside the freezer on the back wall and floor. if you see ice you will need to unstop the drain. (most newer models don't have a removable drain pan)
Nov 08, 2008 | Hotpoint HSS25GFP Side by Side...
There is a water leak somewhere in my 98 toyota camry that leaks into my passenger side floor. There is no sun roof and no visible leaks from the windows or doors. Any thoughts? A/C leak maybe?
Check the A/C condensate drain tube, which is under the glove box, towards the center console, going thru the firewall. If it is plugged, the water in the A/C box will have no place to go & leak onto the floor. This is a common issue, and running the A/C on the "fresh" mode compounds this problem. When the A/C is on, the water removed from the interior is supposed to drain out thru the firewall onto the street.
Aug 04, 2008 | 2002 Toyota Camry
Frigidaire FRT17B3A Top Freezer Refrigerator Logo
85 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
