Question about Toro 15" Electric Trimmer&Edger
Cannot Open Spool Compartment
Cannot Replace Spool As Compartment will not open
  • 1,040 Answers
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
Posted on Jun 21, 2009
  • Jim Parker
    Jim Parker Jun 24, 2009
    Did this solution solve the problem?
    Jim
How do you replace horizontal spool pin
Hi Phyllis I believe this youtube video will help you, Take care...CHEERS..
https://www.youtube.com/watch?v=abGDVhDlZLs
Mar 17, 2016 | Brother Sewing Machines
Need instructions on changing the spool on electric grass trimmer/edger
Turn the trimmer over, I put it in my lap.Remove the orange spool cap by squeezing with thumb & forefinger. It will come right off. Remove & discard(there has got to be something they can be recycled as?) If you are right handed, hold the new spool firmly with left hand with flat side with the arrows up, keep a firm grasp & use small needle nosed pliers(I use hemostats) etc. to free the loose end of the line where it is looped thru the 2 slots. Keeping hold of the spool so it doesn't all unwind, let enough out to feed thru the hole on the side of the compartment where the old spool was. 2-3" will be enough. Then, place the spool into it's compartment with the flat arrow side up.Keep a good grip on the spool until you get it into place. Replace the spool cap by aligning it in the 2 slots that it came from & gently squeezing again until it locks into place & you are set to go. Don't worry about feeding the line out to proper length, it will do that all by it's self.
Aug 03, 2013 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
3.I just got a vintage camera. It's called an Ansco Memar. The full name may be "Ansco Memar Pronto." I didn't receive a manual with it. Can you try to find out how to open the little compartment...
To open the film compartment, pull down on the latch at the bottom of the left side of the camera and swing out the hinged back. Turn the winding spool until the slot is on top. Do not attempt to remove this spool from the camera. Check this webpage for a copy of the manual and these instructions on page 12.
http://pdf.textfiles.com/manuals/CAMERAS/VINTAGE/ansco_memar.pdf
Feb 13, 2011 | Cameras
I have 11" Toro Trimmer and cannot turn spool counterclockwise to replace line. I am a woman and do not know what to do. Used strap wrench large open end wrench and cannot budge this spool.trimmer is less...
With most trimmers, you may have to push the spool casing inward and then turn. It should unlock fairly easy. You may also want to spray the divider crease on the spool casing with some kind of lubricant like WD-40 or Tri-Flow to facilitate the process of detaching the spool casing from the body. Good luck. I hope this helps.
Jun 29, 2010 | Toro Electric Trimmer
My printer spool service is not running
just open task manager and click on new task
then type in spoolsv.exe
your spool service should start.
else open controlpanle and in administrative tasks open services.exe
then fron there right click on spoolsv.exe and start the service.
Jul 21, 2009 | HP Hewlett Packard LaserJet 1022 Printer
Cannot Remove Spool Compartment
Unplug first . Push down on spool easy and turn to were the groves do not line up and pull up . the spring may be rusted . Or a build up of grass is there to. It just sounds like you need to used a little bit muscle . Best of luck Ed.
Jun 18, 2009 | Toro 15" Electric Trimmer&Edger
Film Advance Problem
ksanzo,
The take up spool is cracked at the base causing the spool to slip. The camera must be mostly disassembled to replace the spool ( if available ) . This is one of the very few weak parts in the K1000. send or take it to a camera repair shop for an estimate first. --- or--
separate the base of the spool by pushing down on the gear like wheel and if you find the small crack from the bottom of the spool film slots, very carefully put a dab of super glue on the crack. check both sides of the spool. this works about 80% of the time. however it's better to replace the spool.
Jan 21, 2009 | Pentax K1000 35mm SLR Camera
Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
May 08, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Toro 15" Electric Trimmer&Edger Logo
243 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
