Question about Health & Beauty
Braun 5772 series 3 390cc
How do open a Series 3 shaver?
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
  • 5 Answers
SOURCE: how to replace battery on braun 7526 electric shaver
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Install new circuit board and reassemble
Posted on Jan 07, 2009
  • 10 Answers
SOURCE: I have the same problem with my Braun 7570 as the Jan.8, 2008 writer about the 7526 or 7680 shaver. The blue button came off but the shaver still works
This button wears out or just fails with time, but is replaceable.
Braun 7526 Syncro Body Housing with Trimmer
$12.99, Fits Model: 7526, Type: 5493, Includes back case, front case with trimmer/switch, side grips and bottom 'plug', http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Posted on Aug 29, 2009
SOURCE: Braun Series 7 760cc dead after 2 months
Had this same problem with mine. One month after warranty was done with. I ended up opening the thing up and pulled the monster battery out of its socket and put it back in. Worked fine after that. One week and still strong. Another thing I did was to carefully bend up the flat pieces of copper around the battery to make sure they were still getting a good contact with the pins on the cover. Hope this works for you....
  1. The black rubber/plastic cover on the back will pop off if carefully pried apart from the gray plastic. Start around the middle of the razor body.
  2. Once the black piece is removed you will see four screws holding on a plastic cover. These can be removed with a sharp flat head screwdriver.
  3. The plastic cover can then be pried from the razor body. Be very careful though as there is a rubber seal around this to keep water out. I broke mine.
  4. Inside you will see a somewhat large red battery with prongs on either end. Pop it out of its location and wait a couple of seconds. Press it back into position and you should hear a click for both ends.
  5. After this, I took all of the flat copper pieces and gently bent them towards myself (without making them touch of course... this could cause a short and potentially cause the battery to explode).
  6. Replace everything and see how it works... Hopes this fixed it for you and saved you $100-200. Have a good day!
Also... I am not responsible for any damages that may occur.
Posted on Feb 02, 2010
SOURCE: Braun Model 549 series electric shaver
broken screen braun 549
Posted on May 29, 2010
Braun series 3 390cc, charging base will not clean razor.
Most likely, the pump has stopped working. This is not repairable since part for the cleaning station are not available.
A replacement can be found at shaveroutlet.com
Braun Clean Charge Base 5783 Fits Types 5772 5774
Apr 08, 2018 | Braun Health & Beauty
The cleaning unit on my braun series 3 (350 cc-4)shaver will not work although it will charge after buying a new charging lead? Any ideas?
These cleaning systems are prone to many problems. If the shaver will charge directly from the cord but not the stand, your stand is faulty. They are not repairable since parts are not available. A new stand can be found at shaveroutlet.com if needed
May 07, 2017 | Braun Health & Beauty
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
3) Using a small torq driver remove the 4 screws
4) Open shaver
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Need braun series 7 blades
The blades come mounted in the screen assembly. You will find this cartridge available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
Aug 15, 2011 | Braun Series 7 9585 Hair Trimmer
Braun 4000 series foils
You must be careful when ordering Braun '4000 Series' foils because Braun has made two different 4000 series shaver types that do not use the same parts. For this reason you must use your full model number or type number to ensure that you select the correct parts. If you are having difficulty locating this number, see video at the link below from shaveroutlet.com
http://shaveroutlet.com/locate_model_number_tutorial/
Once you have found the correct number, you can properly select the correct parts. Below, you will find links to both types of 4000 series foils. Match your number to the list of compatible models on the item pages to select the correct one
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-4700-series-tricontrol-foil-p-349.html
http://shaveroutlet.com/shaver-replacement-parts/heads-foils-and-cutters/foil-fits-braun-4000-series-flex-control-twin-control-p-145.html
Jul 23, 2011 | Braun Health & Beauty
We cannot find the directions on how to clean the Braun Series 7 razor
You will find the user manual for Series 7 shavers at shaveroutlet.com. Click on the link below
http://shaveroutlet.com/shavers/braun-790cc-series-7-pulsonic-shaving-system.html
When the item page opens, click on 'user manual' just below the item price
Jul 18, 2011 | Health & Beauty
Health & Beauty Logo
26 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
