Question about Zhone 6211-I3-200 Router
WIFI I RESTART MY MODEM AN HOW TO GET BACK WIFI ON IT
How do i re-enable the wifi in my pc
You state that your wifi "router" will not connect to the internet. That is not inside your computer. The router is the cable modem or dsl modem that transmits the internet in your house. Depending on how it is setup, you may have a second device that separately sends a wireless signal out. The best thing to try first is to turn each device off for 10 seconds and then restart. Some modems have battery backups, so be sure to pull the battery if that is the case to ensure a complete power off. Then restart and see if you have your internet back. This fixes 75% of the issues in this situation.
Sep 23, 2014 | Samsung Computers & Internet
Motorola e365 schematics
Have you updated drivers for the modem or wifi on the system? Depends on the version of windows you have but if u go to search in the start panel and look for devices
and it should show a list of the hardware on your system. Your are looking for anything to do with your modem or the type of wifi connecter on your system. If you don't know do a quick searchon google and look up your pc type and the ask about the type of wifi to specific to your pc. Should give info and then you know what are looking for. Then click on the plus or drop down beside the name of the modem or wifi hardware and click it. A window will open up. Your are looking to the tab with update drivers. Do that and the save everything then restart pc and make sure your wifi is on and setup then try to connect. If that isn't working go to modem or router website and check for updates there specific to your op system and pc . Good luck hope works out.
Apr 15, 2014 | eMachines Computers & Internet
I restart my modem an i want to get back wifi on it
Press the top button for 5 seconds it will the allow wifi to work again
Apr 12, 2014 | Computers & Internet
Won't sign onto wifi network
try reset the wifi device (modem or router)...then restart the chromebook....then try to sign in again...
Mar 02, 2014 | Samsung Chromebook Series 3
Netgear wifi router
1) does it lock up completely or will it work hard lined when wifi fails?
2) do all devices wireless fail or just a single device?
3) do you lose connection to the wireless completely or keep the connection but lose access to the internet? (confusing but very different to me)
in the end you could narrow down the problem but if you have already reset to factory defaults and set back up again and again then it may be time to retire that old router.
Dec 28, 2012 | NetGear DG834G Router
I have a dsl wifi, now i cant get any signal from my ipad2, i use to have no problem for three moths before.
Had same problem when I installed new dsl router/modem.Tap settings ,tap genaeral,bottom of page tap reset,then tap reset network settings.Ipad will reset network and restart.You will have to then go back to set up network again and reenter password if set.Worked for me.
Oct 22, 2012 | Apple iPad 2 Wifi 16GB
Guys..need help...bumili ako ng CDR-KING ROUTER CW-8196..nadedetect ko ung wifi signal pero walang internet access. pero pag direkta sa LAN ung net ko.malakas naman net ko..windows 7 gamit ko...
DUDE..simple lang yan...if meron ka modem...off mo muna modem..
tapos..un-install mo yung "ETHERNET ADAPTER"
den...from Modem connect mo to CDR-king Router - PC, tapos " restart "
and MAGIC...OK na NET MO..pati WIFI...
May 26, 2011 | Computers & Internet
Wireless light on modem is off and wireless service is out. Modem is a 2wire654
Unplug and plug back in the modem from power. If still not working. Restart pc. Or disabled and then enable the wifi network.
May 03, 2011 | AT&T Computers & Internet
How to connect back to the xbox live halo reach xbox 360
Try resetting your modem and wifi router if you are using one. after that restart your xbox, logout form xbox live, and log back in
Mar 20, 2011 | Video Game Consoles & Games
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
Zhone 6211-I3-200 Router Logo
18 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
