Question about Lionel Remote Uncoupling Track O 6-65530
Lionel Remote Uncoupling Track 6-65530 won't unload. Postwar version will. Why?
The current version (6-65530) fails to function when 'unload' button is pressed to operate Lionel milk cars of any vintage. The postwar version of same unit works flawlessly. The current version of track is made in China. What is different?
3 Suggested Answers
  • 34 Answers
SOURCE: CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Posted on Sep 05, 2011
residentoccu
  • 161 Answers
SOURCE: I HAVE A LIONEL 2-4-2 POSTWAR WITH SLOW SPEEDS.
Possibly in need of wheel/pickup cleaning or lubrication.
Also possible that your track need cleaning.
Posted on Jan 19, 2013
I just bought a new lionel o guage remote control track section. My train can run around the oval 3 or 4 times and the uncouple button will cause a coupler to uncouple properly. Then the magnet in the...
sounds like a contact issue clean all connections make sure they fit tightly when a bad connection occures it will cause metal to heat up check both sides of the circuit with an ohm meter
Sep 04, 2012 | Lionel Remote- Control Track with UCS...
I HAVE A LIONEL 2-4-2 POSTWAR WITH SLOW SPEEDS. ANYONEHABE ANY IDEA OF WHY?
Oct 19, 2011 | Lionel Trains Classic Freight Train Set
I have a Lionel ZW transformer older version 1955-1956, And lately my train loses power at one area of the track and then regains power again. This happens on both the outside and inside tracks.
This does not appear to be a problem with the ZW. The XFMR does not know anything about train location on the track. It appears to be a track connection problem on the center or outside tracks or both. One way to identify a bad connection is to take a parallel wire from the common and hot terminal of the ZW and connect directly to the area of track where the train stops and slows down. If this cures the problem then I recommend checking the tightness of the three track connections. For both FasTrack and Tubular, crimp slightly the pin receiving holes in the end of the track.
Note: For both tubular and Fasrtrack it is recommended that common track power for any one section be input to the track at more than one point. In this way one bad outter or center conductor won't cause the train to slow up or stop.
If FasTrack, you can solder directly to the tabs on the track underside for a permanent connection.
Aug 22, 2011 | Lionel Postwar Parts Zw-99 Transformer...
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Apr 27, 2011 | Lionel 12020 Fastrack Remote Uncoupling...
3 year old Lionel 4-4-2 (road number 8632) that will not run on antique track. Does anyone have any insight into whether this locomotive needs a digital power source or if it would have an issue running on...
you may have to use a Lionel transformer for this because some older trains worked on AC current not the DC current that this train uses
Jan 02, 2011 | Toys
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
WE are trying to get our lionel holiday train going. Is there an on/off switch on the train? the part that goes on the track is lit up but when we puch the remote control with train on the track nothing...
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Dec 23, 2009 | Lionel Trains Holiday Express G Gauge...
Why is a ''D'' battery needed for my Lionel Diesel engine?
This is just a guess but it may have powered headlights or other lights on the train at one time, some of then even had a smoke producing device on them.
Mar 19, 2009 | Lionel New Haven Freight Train Set
Lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
Dec 17, 2008 | Lionel New Haven Freight Train Set
Lionel Remote Uncoupling Track O 6-65530 Logo
37 people viewed this question
Top Lionel Video Game Consoles & Games Experts
James Wishart
Are you a Lionel Video Game Console and Game Expert? Answer questions, earn points and help others
