Question about Dometic RM2620 Refrigerator
Installed new rm2620 fridge no power to 12v
Have power to 12v wires until hooked up to fridge then no power at all on meter check and no power to control panel
    Top Expert:
  • Dometic Master
  • 8,688 Answers
Check fuse if one or bad control board
Posted on Jun 21, 2016
2 Suggested Answers
  • 20 Answers
SOURCE: Dometic RM2652 was working fine then stopped - no lights at the control panel above the doors.
The yellow powdery material shows you have a leaking cooling unit....as far as the the controls go about 4 inches above the flame on the insulation tube there should be a overheat sensor(2red wires) push the button in the middle and your fridge should turn on again. The heat sensor trips because the ammonia system leaks out and overheats the system. The sensor is there to prevent fire and if your cooling unit is leaking you should not keep running the fridge
Posted on Jan 30, 2015
How to hook up a 12 volt wiring from converter to fridge
Is this a new fridge or the one that came in a trailer? If it is installed it should be wired, have you checked fuses? If it's not installed there should be instructions with the frig or check the Dometic web site.
Aug 01, 2014 | Dometic RM2193RB Compact Fridge...
Ammeter wiring how do I wire -20/+20 12v gauge to 4 batteries wired in parallel in my caravan ? I have 480w of solar power, 4x120 a/h deep cycle batteries.I run 12v fridge, 12v TV plus lights,pumps,...
4 batteries in parallel equal 480 a/h so if you pull 10 amps as an example it would last 48 hours. To measure current the amp meter would have to be in series with the total output of the four batteries. If you go between the batteries current is divided due to being in parallel Divide the total a/h by the current being drawn to work out the time frame .
Jan 16, 2018 | Kitchen Appliances - Others
Won't work on any power source
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620 28c4e1ea-6951-42e3-827e-9b9809f394fb.jpg
Mar 09, 2014 | Dometic RM2620 Refrigerator
How do i fix a fisher price power wheels jeep
If you have a volt meter, switch the volt meter to 12v, locate the motor in the back wheels and if you can see where the wires connect to the motor touch the terminals of the volt meter to the two connections and turn on the power wheels press the power pedal and see if you get a reading of 12v. If you can't touch the wire or where the wire connects try disconnecting the wires and testing it that way. If you have 12v at the motor then it seems the motor is shot. There should be two motors one fit each wheel and its unlikely that they would both go. If you don't have power at the motor try following the wires to the pedal and also the forward reverse switch. Test these in a similar fashion. Hope that helps
Nov 20, 2013 | Baby Gear
Wire hook-up
see schematic on side of inside back cover if 120 volt plug that goes to outlet then if 12 volts from black and green ground go to block they should be marked
Jun 18, 2013 | Dometic RM2620 2 WAY REFER
2 year old RM 2620 fridge, stopped working. I have power to the plug where it plugs in, but there's no lights or cooling now. Fuses are fine.
On the back side of the unit there will be a small thermostat switch mounted on the heat column. It will be round with two wires attached to it. In the center is a reset button. If this button does not restore power then the next step is to replace the wire coming from 12v supply to the thremostat switch. The wire will be red and will have a black sleeve on it. Under the sleeve is a safety diode (to prevent overheating and fire), it will be held in place with three bendable metal fingers. If the diode is bad it will not allow 12v power to pass through to the circuit board. Even though the refrigerator is running on 110v power the circuit board still requires 12v power to operate. The diode is a part of a FREE recall kit offered by Dometic so your local RV repair center should be able to help you out.
Oct 17, 2011 | Dometic RM2620 Refrigerator
New cd player made in china
The yellow wire does not get used unless you have a power antenna to hook it to. The red wire is suppose to be hooked to the wire that was used as power for the stock stereo, so it turns on and off with the key. If you have it hooked to constant power, it has power coming to it even when it's turned off. That and the fact that you may need a better ground is most likely the reason you're getting the moise even when turned off. You may also want to check your speaker connections.
Oct 08, 2008 | 1993 Ford Explorer Limited
I have an Alpine Model CDM-9821. I just bought another vehicle and want to install my alpine in it. I have all of the wiring hooked up properly but am unable to get my unit to power up. I have 12.5...
did you use an installation harness? you should have the following when you test-
red wire-12v only with key on
yellow wire-12v at all times
reverse your test light to check the ground wire should be 12v with test light hooked to pos
Jun 20, 2008 | Alpine Car Audio & Video
Dometic RM2620 Refrigerator Logo
69 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
