Question about Cuisinart CBT-500 SmartPower Premier Work Top Blender
My locking ring is stuck on my Cuisinart Blender how can I remove it?
4 Suggested Answers
SOURCE: cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Posted on Nov 02, 2007
SOURCE: parts for cuisinart blender trio model bc-56
GO TO:
http://www.smallappliance.com/department.asp?cur=USD&sid=18954&mid=8&shopBy=Brand&cam=cuisinart_parts&gclid=CJTy7Om5qZoCFRk_awod9Gjw1Q
FOR CREDITS MAIL BACK TO: NEFIUINC@MSN.COM
Posted on May 07, 2009
  • 3 Answers
SOURCE: How do you remove the
i have a perfect answer! and own this very modle with the same issue. Plus i have done it myself.
Instructions:
*on the lower part of the hadle you will see two holes, with a small 6" school sized METAL ruler (no thicker than 3/4mm) gently insert it inbetween the two holes and push down. ((The handle has a clamp there) NOTE: you MUST start at the bottom of the handle or you will brake it!
*then while still inserted push the ruler away from the jar. this should releese the clamp that will allow you to remove the outer piece. REMEMBER your handle is plastic.
*now slowly lift upward and the side clamps will release. STOPpulling when you get to the at the top clamp.
*now you want to carefully hold your thumb down with slight pressure on the top of the handle (where you see the ingroved space that connects the hadle piece, it looks just the same as the bottom but without the holes) and lift up the handle slowly. this should release the outter part of the handle.
* now that the outside piece of the handle is off you can see the scews, unscrew with a phillips scewdriver and take handle fully off.
*Lastly the wire-like rings MUST be slipped off towards the bottom. do NOT try to prie off the wire-like ring from the little piece that is holding it together to create the ring, you will snap it.
*after you have taken off the rings, clean them with VIM (with bleach) by placing them FLAT on the sink edge to keep them from changing shape. Scrup away. Also scrub the plastic parts but DO NOT use the VIM on the outside of the plastic handle as it could scrub away the silver paint. only do this on the inside to remove the mold and grime.
NOTE: VIMis the only thing i found that will even remove rust build up. use an old toothbrush to scrub away the rust and grime. preferably dry with the vim, no need for water. water will dilute the VIM and cause it to be uneffective.
* you can take the little nub that conects the rings off by twisting them to the left or right, for cleaning, doesnt matter. I tried both ways but prefer to keep them on.
* now that you washed all parts let them DRY or you will end up with the same rust and grime issue. After the parts have dried you can now reasemble youir handle, and have peace of mind :)
* Try not to overdue the assable and reassambling of your handle, keeping in mind it is made of plastic and plastic wears easliy.
Hope that helps.
Posted on Jul 30, 2011
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
Blender Base is stuck and won't budge
Please use the WD-40 and let by 1 hours, and ready.
God bless you
Nov 06, 2013 | Cuisinart SPB-7CH-LR Blender Jar Base
Manual is destroyed. Need new copy for Cuisinart PowerBlend Blender/Food Processor
The Instruction Booklet for your Cuisinart BFP-703 SmartPower Work Top Blender can be found here:
http://www.cuisinart.ca/pdf/ibs/en/BFP-703CHC_en.pdf
Thank you for using FixYa!
Jul 30, 2011 | Cuisinart BFP-703 SmartPower Work Top...
I want gasket for cusinart blender (600watt.)
mcdevito75 here, You should be able to contact Cuisinart omline at Cuisinart.com to reder new gasket.
Jun 28, 2010 | Cuisinart CB-600 Blender
Cuisinart fpb-5ch blender not working
Remove blender attachment completely, turn machine on and see if it will spin with all attachments removed - if it spins, then replace the blade assembly - parts available from Cuisinart. If it doesn't spin, send to Cuisinart for repair (call first).
Dec 11, 2008 | Blenders
Cuisinart bc56 blender
how to get the base off the glass container. turn in what directionss it seems stuck
Feb 27, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
Black plastic "ring" that fits over the spindle on the motor base snapped
I just bought a replacement part on ebay. It cost about $11, which included shipping. buy-it-now-store.com
Jan 16, 2008 | Cuisinart SPB-7 SmartPower Work Top...
Cuisinart sealing gasket
Aug 15, 2007 | Cuisinart SPB-7 SmartPower Work Top...
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Cuisinart CBT-500 SmartPower Premier Work Top Blender Logo
107 people viewed this question
Top Cuisinart Blenders Experts
eyecam
ray gallant
richie46
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
