Question about Vacuums
How do you remove attachment - Vacuums
Remove handle from hose electrolux
You don't have to "remove" the handle from the hose to attach other attachments, just depress the tab at the end of the hose and pull the upper wand loose then use the "adapter" to use the dusting brush or simply snap the crevice tool in place to use. If the handle won't come loose from the upper wand, then the described "tab" needs replaced as it's locking up the parts. Hope that helps!
May 17, 2014 | Electrolux Vacuums
How to attach crevice tool
Hi! Below is step-by-step instructions for attaching your crevice tool.
1. Place unit in an upright position. Push release button forward, then pull handle from unit.
2. Remove floor tool from nozzle.
3. Attach crevice tool by inserting into nozzle. To remove gently pull apart.
Hope this helps out!
Apr 26, 2014 | Dirt Devil Simpli-Stik 3-in-1 Bagless...
Remove hose from 66T6
I know how frustrating this can be. Try turning the hose and wands in opposite directions where they connect. Once the hose and wand is separated you'll be able to connect the pet hair attachment.
Here's a quick link to obtaining a copy of the user guide if you've misplaced yours:
http://www.bissell.com/user-guides/?cid=ccsocial
Feb 07, 2013 | Bissell 66T6 Pet Hair Eraser Cyclonic...
Lost manual. How do i hook up the suction part of the furniture upholstery attachment? I know where to plug it in to spray cleaner on the furniture but where does it plug in to **** it up? Model...
on the attachment where you put the attachment remove the lid, then remove the back panal, and slide the suction thing down not much pressure, re apply the lid then put back in vacuum, turn on and there you go...
Sep 02, 2011 | Hoover F5906-900 Upright Steam Vacuum
How do i release. the hose to attach the attachments?
Near the carpet attachment, on the lefthand side of the hose, there should be a release mechanism that you simply push in with your foot while pulling on the hose/wand. Once the carpet attachment is removed, you can connect the other attachments. Push the release toward the hose.
Nov 04, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Cannot remove attachment from proteam super quarter vac
Greetings, The ProTeam backpacks us a 1.5" hose and attachments. The way that the floor tool is removed is by unscrewing the collar of the attachment. Simply turn counter clockwise on the the part of the attachment that is secured to the wand and doesn't rotate. This should loosen the floor attachment, and you may then pull it off. The other floor attachment can be fitted, and then screwed on by rotating the opposite way, clockwise which will secure the attachment to the wand. I really hope that this information was helpful to you. If you ever need parts or supplies for your ProTeam, please be sure to check out GoVacuum dot com. If this was helpful to you, please rate the repair as helpful by clicking the 4 Thumbs up icons in the top part of the repair. Thank you very much, Chris J. GoVacuum
Mar 23, 2010 | Vacuums
ATTACH UPHOLSTERY ATTACHMENT
What is the Model Number of the Steam Vac?
It should be something like F58XX-XXX
Sep 29, 2009 | Vacuums
Help with steam cleaner
DId you push the little button located at the rear of the attachment on the top? It is gray and part of the hose peice. It is what holds it the attachment to the tube
Jan 31, 2009 | Bissell 1699 ProHeat Clear View Upright...
Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Oct 23, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
