Question about Garden
1998 belarus 5370 tractor rear remot hydraulics trouble
2 Suggested Answers
  • 2468 Answers
SOURCE: ran tractor out of fuel try prime got fuel to pump
you need to open the fuel line at the injector on the cylinder to get the air out of the line while still priming the pump ,its building back pressure and fuel cant get past the pump,another way would be is to remove the air cleaner and carefully get a spray container of diesel fuel and spray directly into the air intake and see if it will fire,if so it may pull the air lock thru when the engine starts and till it gets fuel from the pump directly and runs on its own
Posted on Mar 07, 2010
Should a 500 belarus have down pressure in the hidrolics
Hey Austin, I am assuming you mean have pressure in the hydraulic system when you are lowering anything.( like a bucket). ?? .YES, if not, it would just free fall with no control..
Jul 12, 2017 | Cars & Trucks
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
Jan 01, 2016 | Ford Cars & Trucks
Where can I find parts and instructions on how to repair the hydraulic rear remote level selector on a ford 4000 1965 Gas Row crop tractor?
what ive found on these oldies are that they borrowed the seals from there car/truck line , me id remove the leaking seal and take it with you and find an autoparts guy that's willing to look up an item by size/description then I bet you could buy a seal that would work for you
also for seals/bearings a company called timkin has a fantastic web site that allows one to get a part number by size !!!
Nov 16, 2015 | Ford Garden
Does rear end oil and hydrodaulic fluid go in same reservoir
Ford 8n's use a commion sump, rear end, transmission and hydraulics. Ford called for 80 or 90 weight gear lube depending on temperature (winter/summer) about 5 gallons The link below is a great article on proper oil and maintenance....Hope this helps...
< http://www.myfordtractors.com/hydraulics.shtml > Ford Tractor Hydraulic System
Jul 26, 2014 | Ford 8N Tractor
A kubota tractor...... the hydraulics are frozen
Clean the filter in the transmission housing. Its right on the bottom of the rear wheel transmission housing RH side. Watch the oring, its very thin and easily damaged.
Dec 27, 2012 | Garden
My rear hydraulics on my 1979 case 1370 tractor
Sounds like you have a hydraulic cylinder bypass problem on the disc
May 09, 2012 | Diesel Case 1370,1470,1570 Tractor Piston...
Where is the rear end fill and level holes on a Farmall 400 Diesel?
Just check you hydraulic and transmission fluid levels,the rear end is lubed with hydraulic oil that is supplied by one or the others oil reservoir.
Mar 21, 2010 | Diesel Farmall Tractor 400,450 Gas & ...
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
