Question about RTO Shinerich #SREH03 FS Electric Patio Heater
Assemble shinerich patio heater Model srph31 valve
Fix patio heater valve.
I have a Kirkland patio heater model # PTH-106SS-3G the pilot will not stay lit. Do I need to replace the whole pilot assembly
Hi, If the pilot light goes out when you turn the gas knob to full power on lighting them the most likely cause will be a worn thermocouple, these usually last between 2 years up to 6 years. Found this site very helpful, patio heater problem solving. They have a few solutions to checking patio heaters.
Oct 12, 2011 | Williams 2509612 Ceramic Mid-Size Heater
I have an RTA International Patio Heater, Model 385.001 with a clogged pilot light valve. I need a way to fix the problem or a new replacement part. I have a commercial gas heating repair company working...
Gas Valves are not meant to be repaired only replaced. So I would have them replace the part and have them warranty there work. If the heater is very old and the replacement part is going to be half the cost of a new one You might want to put that Money on a new one and get a New manufactures warranty in the deal. Just another point of view....... Hope this helps
Feb 07, 2011 | Rta International Patio Heater
Flame out on a DCS Patio Heater
thermo-coupler (cheapest to fix) or valve
Jan 30, 2010 | DCS PHFS Phoenix III Outdoor Patio Heater
Need parts: pilot assembly and thermocouple
THe thermocouple either has 2 wires or a coppr tube going to the gas valve. They can be bought at a good hardware store or a plumbing supply. The length of the wires or copper tube will be the determining factor as to which one you need. As these thermocouples, when heated generate a small electric charge tha keeps the gas valve open. Should cost no more than $10-15 USD
Oct 10, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Hello, I bought a Leisure Patio Heater Model TD 101. The assembly inst. were not in the box. Please help me. Thank you, Samuel
you got to be more specific, have you put it together yet? if so, make sure you have the fuel connected right. insure the connector is all the way and tight, incide the valve is a safety divise that if it is not putched all the way in, the valve wouldn't open.
Sep 08, 2009 | Leisure TD125 Patio Heater
GAS is to getting to ignitor for my patio heater model # 385.001
I assume you meant gas is not getting to the ignitor, take apart the head, if you are comfortable with it, and check for a blockage in the pilot assembly. If this does not fix the problem, try replacing the regulator.
Jun 24, 2009 | Rta International Patio Heater
Need Owners Manual/Assembly Instructions for WindChaser PHS Patio Heater
I have the exact same problem. No owners or assembly manual. Can get no response from company?
Nov 04, 2008 | Windchaser Stainless Steel Patio Heater...
Patio heater won't lite
There is possibly a spider web or wad of web blocking the gas flow between the valve and pilot.Take the line off between the valve and pilot and blow it out with compressed air and it should fix the problem.
Aug 23, 2008 | Sport & Outdoor - Others
RTO Shinerich #SREH03 FS Electric Patio Heater Logo
66 people viewed this question
Top RTO Pool & Spa Experts
john h
old fart58
Craig Butler
Craig Butler
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
