Question about Refrigerators
Norcold refrigerator door pops open - how can I fix please?
  • 210 Answers
SOURCE: Freezer Door Popping Open
Look at the bottom of the freezer door, there is a little plastic stopper there. It may be worn out or broken. When you close the door this is what holds it there. Start there first.
Sgt 48
Posted on Jun 17, 2008
SOURCE: Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Posted on Dec 25, 2008
  • 38 Answers
SOURCE: refrigerator door keeps popping open
Level refrigerator with front 1/4-1/2 bubble too high in front.
Posted on Mar 08, 2009
  • 105 Answers
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
Posted on Apr 17, 2009
  • 19 Answers
SOURCE: side by side freezer door pops open
This is a problem inherent with lots of refrigerators. Side by side or top freezer. The rush of air pops the doors. You might want to adjust the pitch of the box by adjusting the front wheels to a higher level.
Posted on Jun 18, 2009
I have a Norcold 2 door fridge. It works fine on propane or electric but I hear a VERY loud bang and see flames shoot out. It is a propane leak some place but checked fittings and lines -no leaks.
is this new? never been used before or old. ? please read this
Norcold, Inc. Product Recalls - Call 1-800-767-9101 Monday - Friday 8:00 am to 8:00 pm EST
The Norcold, Inc. refrigerators listed below have been recalled.
It is important to implement this safety enhancement to prevent an unsafe elevation in the temperature of the cooling unit should the unit fail in operation. This enhancement seeks to minimize the risk of injury or ***** due to fire.
Norcold Inc. has decided to recall certain 1200, 1201, 1210 and 1211 model gas/electric refrigerators with serial numbers from 315525 to 13088811, non-consecutively. The refrigerator's model and serial number are located inside the fresh food compartment. These refrigerators may have cooling units with a cooling unit serial number between 700000 to 13085759. This is a new recall campaign to include all 1200, 1201, 1210 and 1211 models.
Even if your refrigerator was repaired as part of a previous recall, it is necessary to have it repaired again to minimize the risk of injury or ***** due to fire.
If you have one of these refrigerator models, use the following procedure:
  1. Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
  2. Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
  3. Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
  4. Call your dealer immediately.
The installation of the High Temperature Sensor will be at no cost to you.
Owners of recalled refrigerators should NOT operate their refrigerator until it can be professionally repaired by your dealer or a Norcold authorized service center.
If you have one of the recalled refrigerators and you:
Currently reside in the RV, you should immediately:
  1. Set the refrigerator controls to "OFF".
  2. Unplug the refrigerator through the service vent on the outside of the vehicle.
  3. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Do not currently reside in the RV, you should immediately:
  3. Disconnect from shore power.
  4. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Failure to follow these instructions can result in a fire causing injury or *****. To locate an authorized service center,
http://webcache.googleusercontent.com/search?q=cache:tnsP3IdSqhgJ:www.thetford.com/customer-support/recall-information/+&cd=10&hl=en&ct=clnk&gl=uk
if you have this model STOP using it!!!
Jun 19, 2017 | Refrigerators
THE HIGH TEMP.LIMIT SWITCH IS OPEN NEED LOCATION
The high temp switch connects to your power board at "Limit In" and "Limit Out". Follow those wires to the switch. I would see if you're under the Norcold recall. Give them a call and check. If you're not, here is where you can get an upgraded thermal switch:
Norcold High Temperature Limit Switch V2 0 by ARPrv
Apr 24, 2016 | Norcold Inc Norcold 1210IM Refrigerator
Light in refrigerator does not go out when door is closed. We replaced the switch but the light still stays on when door is closed. Can you tell me what the problem is?
To make your search simpler and understand the way to search Norcold Manuals is to always remember Norcold and Dometic models will always come up with different search names. Confused? Click here to bigin your search=> Norcold If you are unable to get results then click=> HERE Once and at top and bottom of page=> Here you may contact me for more answers to your questions regarding your NDR1292, Thanks, Sea Breeze
Mar 20, 2011 | Dometic NDR 1292 Refrigerator
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
My Norcold DE0051 I have to keep defrosting every 2 weeks
Occasional defrosting is needed on these units. 2 weeks isn't that bad considering the environment that it is in (your boat). Every time that you open the door, moist air enters the fridge, and the moisture eventually collects on the freezer plate, and freezes. Putting foods into the freezer that are uncovered also contribute to this a great deal, as do putting in warm / hot foods before giving chance to cool down.
These freezers do not have automatic defrosters. The target environment typically has limited power available. Automatic defrosters would easily double the power requirements.
You can also check the door seals on your fridge as well. If they are not sealing properly, they can also let in humid air which then causes moisture to collect on freezer plate.
Aug 10, 2009 | Thetford Norcold DE0051 Refrigerator
Refrigerator door keeps popping open
Mar 08, 2009 | Refrigerators
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
