Question about Saws
Rexon bandsaw BS12
How to align blade on wheels
    Sergeant:
  • 468 Answers
Read these blogs http://bandsawblog.com/band-saw-wheel-alignment/
http://www.doityourself.com/stry/basic-band-saw-blade-alignment-and-tracking-procedures#b
Posted on Apr 15, 2014
SOURCE: Grizzly bandsaw cannot fit blade
I lowered the spacer (on the threaded rod) and got enough drop in the upper wheel to fit the blade.
Posted on Jan 12, 2009
efs_perpends
  • 1996 Answers
SOURCE: bandsaw blade keeps coming off Rexon BS 10
Unplug the saw and take the covers off the wheels. See if any of them show excessive end play or deflections when gently racking them from side to side. You may need to shim the wheels. Ideally, you want them all to track in the same plane, and you can check this with a straightedge.
There should be a tracking thumbscrew locked with a wing nut or some such on the back of the upper wheel. Put the blade on so it rides in the center of the tire, (move the guides out of the way if need be until you get the blade to track correctly), and turn the wheel by hand to see how the blade rides. That way you can make adjustments before it pops all the way off. By moving the bolt on the back of that upper wheel in or out you adjust the pitch of that wheel and change the way the blade tracks...
After you get the blade tracking smoothly under tension, you can move the guides back into position to support your blade during cuts.
Posted on Apr 20, 2009
  • 58 Answers
SOURCE: upper wheel on a model 28-682 bandsaw. How do you adjust it.
With saw unpluged!!!!! open top wheel gaurd.Spin wheel by hand while moving the adjuster knob on back of the machine. As you turn both at the same time the blade will trac either the front or back of the wheel. Move the knob (while spinning the wheel) until the blade is tracking in the middle of the tire. (rubber strip around the wheel)
Posted on Jun 13, 2009
  • 582 Answers
SOURCE: bandsaw blade keeps coming off the wheels. What
ALL BAND SAWS HAVE AN ADJUSTMENT FOR THE BLADE TRAVEL WHEN I WOULD REPLACE MINE I WOULD ROTATE THE TOP WHEEL BY HAND TO CHECK THE ALIGNMENTAND WATCH WEHICH WAY THE BLADE STARTS TO TRAVEL THERE SHOULD BE AN ADJUSTMENT ON THE TOP WHEEL THAT TILTS THE WHEEL IN OR OUT JUST A TINY TURN WILL MAKE A BIG CHANGE
Posted on Aug 22, 2009
  • 302 Answers
SOURCE: clark 6x4 bandsaw
there should be an adjustment knob on the back that changes the angle of the top wheel and this will center the blade so it stays on. I do this by jogging the saw on and off while I adjust it. hope this helps you
Posted on Sep 24, 2009
I have a DL3000XL bandsaw and suddenly the sawblade keeps slipping off with just one turn. I have adjusted repeatedly. I bought a new wheel for top and bottom and it didn’t help at all.
When you say "adjusted" do you mean you adjusted the alignment on the bandsaw? Generally, the blade will slip of when the top and bottom wheels are not aligned. As luck would have it, I saw your post the same day you posted it.
To see how to align your bandsaw, view this:
https://www.youtube.com/watch?v=i7LthZwbimA
Oct 05, 2017 | Saws
REXON BS 10 .3 WHEEL BANDSAW 20 YEAR OLD , WHAT IS MAX BLADE WIDTH I CAN USE . THANKS
open it and measure the drive wheel width . only a guess but 1/2 in might be all
Feb 02, 2017 | Blade Saws
The blade won't stay on even though I have it on properly it comes right off when I turn it on
I have no experience of portable bandsaws but do have some experience of workshop bandsaws.
One wheel is generally movable in order to "steer" the blade and careful adjustment is needed with the blade guides retracted until the blade runs full on the wheels. The blade guides are then brought back to prevent the pressure against the work from pushing the blade off the wheels.
Oct 04, 2015 | Milwaukee tools 6242-6 Compact PortaBand...
Searching for trunion table mounts for Rexon MBS 380S Bandsaw
I can't find any good supplier. I checked on the site ( bandsawparts.com) where I lastly purchased guides but they don't have parts for Rexon band saw . Try calling Rexon 01709 876611 . Hope that helps!
Aug 08, 2013 | Saws
I have an 18v Milwaukee bandsaw (model #2629-20) and the blade is constantly slipping off the wheels. I'm thinking it's an easy fix but not sure exactly what is causing the problem. Please hel
Possible causes:
- Tires: If the tire(s) on the front or rear pulleys are worn, torn or have chuncks out of them, the blade can slip off.
- Pulley(s) out of line: If either or both pulleys are out of alignment the blade will work it's way off. This could be caused by a worn pulley hub; a worn or broken pulley axel; or worn, broken or frozen bearings where the axels turn. On the drive pulley this could include the bearings on the drive shaft or the boss where the bearings fit into.
- Blade: If there are any kinks or slight bends in the metal they could cause the blade to work off the pulley.
Mar 07, 2012 | Milwaukee Tool Saws
Sorry as i have extremely little amount of info on this machine (not mine ) i said i would fix it for her it is a 3 wheeled machiene made by rexon i asked for the model & was told all she could find...
Brand of bandsaw is of no importance, problem is... You did not stated what is exactly the problem, I assume therefore tha tproblem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you still have some trouble with your bandsaw, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 13, 2010 | Saws
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Bandsaw blade keeps coming off the wheels. What
Aug 22, 2009 | Craftsman Saws
Upper wheel on a model 28-682 bandsaw. How do you adjust it.
Jun 10, 2009 | Saws
Bandsaw blade keeps coming off Rexon BS 10
Apr 10, 2009 | Saws
Saws Logo
224 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
