Question about Facebook Apps
Dns server when i try to load nightclub city it says Unable to resolve the server's DNS address.
Hypnotoad
  • 55 Answers
SOURCE: Xbox DNS server
Go to start->run on your computer, and type "cmd"
When the command prompt comes up, type "ipconfig /all", this will list all of the information about your IP address. Find the DNS Servers option, and copy that onto your xbox.
Posted on Feb 14, 2008
Benimur
  • 6966 Answers
SOURCE: dns of globe broadband
Locally (in your network) to gather these information, you can enter http ://192.168.0.1/ to get the Actiontec’s web interface and gather the DNS info.
Alternately, for Globelines (Philippines) DNS Servers, you can try:
  • 202.52.163.6
  • 202.52.163.7
  • 202.52.162.39 (ns1.globeidc.com.ph)
  • 202.52.162.40 (ns1.globeidc.com.ph)
  • 202.52.167.70
  • 202.52.167.71
Depending on the time of the day, below DNS varies in performance/speed:
  • 203.127.225.10 (g-net.globe.com.ph)
  • 203.127.225.11 (g-net1.globe.com.ph)
In some instances, the following also work:
  • 202.95.226.66
  • 202.95.226.77
The below DNS could also be used but would seem to be reserved for somebody way up the company:
  • 203.177.3.100 (theboss.globenet.com.ph)
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 21, 2008
  • 13 Answers
SOURCE: netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Posted on Feb 06, 2009
ripleymojica
  • 643 Answers
SOURCE: dns server error
in the dns server # type in 4.2.2.2 and 4.2.2.1 that should fix the error
Posted on Jun 02, 2009
  • 1297 Answers
SOURCE: E-mail error #802
The code is the malfunction on the DC power fan parts.Clean,vacuuns the fan.
Posted on Sep 01, 2009
Dns error laptop
Instructions
    • 1 Refresh the page that failed to load. If the page reloads, you just had a momentary lapse in service that happens with most providers. Between each following step, try refreshing the page to see if the problem is resolved.
    • 2 Check the page address you typed into the address bar to make sure it is spelled right. An error in the URL address could cause this error message.
    • Sponsored Links
    • 3 Go to your connection settings and make sure the settings match those of your Internet serviceicon1.png provider or local area network. Do this by clicking on Tools on the toolbar, then Internet Options. Under the Connections tab, click Settings.
    • 4 Click the "Detect Network Settings" link on the Interneticon1.png Explorer page accompanying the error message to let Windows try and find an optimum connection.
    • 5 Download DNS error fix softwareicon1.png off the Internet if no other option works (see Resources). The software is free on some websites and should be able to identify the problem and correct it.
Nov 21, 2013 | Lenovo Computers & Internet
Tip
Server 2003 & client configuration
<p><span>Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food <span> </span>with printer for billing.I</SPAN><br> <p><span>Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.</SPAN><br> <p><span>You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.</SPAN><br> <p><span>Before Starting the DC installation process you need to make sure the <span> </SPAN>following points</SPAN><br> <p><span> </SPAN><br> <p><span>1)You have installed Basic windows server 2003 installation</SPAN><br> <p><span>2)Make sure you have assigned a static ip address to your server</SPAN><br> <p><span><span> </SPAN>Now start DC and DNS Setup process</SPAN><span></SPAN><br> <a><span> </SPAN></A> <span><span>Domain Controller</SPAN></SPAN><span></SPAN> <span>Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory. </SPAN> <p><span>Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests. </SPAN><br> <a><span>DNS (Domain Name System)</SPAN></A><span><span> </SPAN></SPAN><span>Role</SPAN> <p><span>Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.</SPAN><br> <p><span>DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.</SPAN><br> <a><span>Print Server Role</SPAN></A><span></SPAN> <p><span>In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:</SPAN><br> <p><span></SPAN> <br> <p><span>Printer Priority</SPAN><br> <p><span>Network Printers</SPAN><br> <p><span></SPAN><br> <p><b><span>Client Configuration :- </SPAN></B><span>After</SPAN><span><span> Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Use the following DNS server addresses</SPAN></b><span><b><span>,</SPAN></B></SPAN><span><span> and then type the preferred DNS server and alternate DNS server IP addresses in the</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Preferred DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>and</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Alternate DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.</SPAN></SPAN>
on Feb 15, 2011 | Computers & Internet
Eror 105 wifi
Error 105 is one of the most commonly faced errors by a lot of users everyday who are using Google chrome
Error 105 is a DNS resolution error. - Which means when you enter the URL of the website and hit enter in Google chrome, it tries to resolve the IP address of the website using a protocol called DNS (Domain Name System). If chrome is unable to reach the DNS server, the name resolution fails and you get the error 105.
Solution:
Once you have verified from your internet service provider that there is no problem on their end, follow the step by step instructions below.
We are simply going to add a manual DNS address in Windows so that chrome is able to resolve DNS queries.
1) Press [Windows Key + R] to open the "RUN Dialog"
Alternatively, you can also click on the start menu, type run in the search bar, and you will have the RUN Program.
Once you have the RUN box, type in ncpa.cpl and click OK - This would work for all Windows operating systems including Windows Xp, Vista and 7.
2) Next, Choose the correct network adapter (from the icons)
If you are connecting to the internet using an Ethernet cable, then most likely you are using a desktop computer. Right-Click "Local Area Connection" and click "Properties"
If you are connecting to the internet using a Wi-Fi Connection, then Right-Click on "Wireless Network Connection" and click properties
3) After you open the properties window, select "Internet Protocol Version 4 (TCP/IPv4)" and click "Properties"
4) Usually you would be having both the options set to "Automatic"
In the section below, select the "Use the following DNS Server Addresses" and enter the following values Preferred DNS Server - 8.8.4.4
Alternate DNS Server - 8.8.8.8
and click "OK", then click "CLOSE"
You must now test your new configuration by browsing a website - you can also try and browse the website you were trying to get to when you got the error 105.
Jul 06, 2012 | Microsoft Windows XP Media Center Edition...
Unable to connect to http://coredjradio.ning.com
Are you behind a website blocking appliance? If so, check the whitelist/blacklist.
Also, check your hosts file and make sure here is no entry for these sites, then perform the command "nslookup coredjradio.ning.com" to see if you can resolve an IP address for the site from DNS. If you don't get an IP address, check your DNS settings and try again.
Once you can resolve the site's IP address, check your firewall(s) to make sure HTTP port 80 is allowed to this site.
Jun 08, 2012 | HP Computers & Internet
Kodak printer ESP C310 printer not responding error code 105-100003
for more help visit CBR Tech Solutions
Sep 23, 2011 | Office Equipment & Supplies
I cant play nightclub city... loading issues
NightClub City game results in the DNS can not resolve the cause of getting a statement from
May 29, 2011 | Nightclub City
I cannot communicate with primary dns server 172.29.71.1 is there a way i can reset it automaticaly or manually
You cam try doing a power cycle. Turn off the modem, router (if you have one) and your computer. after 1 minute turn on modem first then router and computer. If you still can't communicate or ping the DNS it could be a firewall that is blocking it.
Oct 08, 2008 | Computers & Internet
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Dns error
DNS = Domain Name Server
This is a set of specialized servers on the Internet, needed to
translate user friendly internet address such as:
www.microsoft.com
into their binary IP address equivalents, such as:
www.microsoft.com =
207.46.192.254 = (IP address)
$CF 2E C0 FE = (hexadecimal)
1100 1111 0010 1110 1100 0000 1111 1110 (binary)
In order to communicate with Microsoft, your computer
first sends a request to the closest DNS server to resolve
the domain name into a binary address. Once it gets the
binary address of Microsoft, in then prefixes every packet
with a 32-bit destination address, followed by it own 32-bit
return address.
Other specialized computers on the Internet, called routers,
than manage the actual data transfers on a skip by skip basis.
A DNS error means that your computer is either unable to reach
the pre-determined DNS server, or the server is unable to resolve
the particular address due to a non-existent WEB site or a
spelling mistake.
The actual meaning of the message depends on which layer
of the internet protocol in your computer, (or outside of it)
generated it.
Martin.
May 08, 2008 | Computers & Internet
Facebook Apps Logo
152 people viewed this question
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Facebook App Expert? Answer questions, earn points and help others
