Question about Tablets & eReaders
Vidao v9tab16d maze lock - Tablets & eReaders
I have a amazon fire hd 8 how can i chang the pic. on the lock screen please help
Select a lock screen scene or personal photo to display on the lock screen of your Fire phone.
  1. From Settings, tap Lock Screen, and then tap Select a lock screen scene.
  2. Swipe down through the available scenes, and then tap to preview the lock screen. Alternatively, tap Your Photo to select a personal photo to display.
  3. Tap the checkmark to set the lock screen or the X to cancel.
By default, your phone will rotate through all of the available lock screen scenes daily. To turn this feature off, tap Off next to Rotate Scene Daily at the top of the screen or select a specific scene.
Note: When the battery is low on your Fire phone, Dynamic Perspective lock screen scenes will stop reacting to your movements to conserve battery life. From time-to-time, we will add additional lock screen scenes to your Fire phone when they're available.
Dec 27, 2016 | Amazon Tablets & eReaders
How do I factory reset my lg7530 ?
  1. Turn the phone off.
  2. Press and hold the following keys at the same time: Volume Down Key volumedn_key.png + Power/Lock Key powerlock_key.png on the back of the phone.
  3. Release the Power/Lock Key powerlock_key.png only when the LG logo is displayed, then immediately press and hold the Power/Lock Key powerlock_key.png again.
  4. Release all keys when the Factory hard reset screen is displayed.
  5. Press the Power/Lock Key powerlock_key.png to continue or either of the Volume Keys volume_keys.png to cancel.
  6. Press the Power/Lock Key powerlock_key.png once more to confirm or either of the Volume Keys volume_keys.png to cancel
Jun 24, 2016 | Tablets & eReaders
My vidao tablet won't turn on
Can you open up the back where the battery is located? check the contacts for cleanliness and replace the battery .Sometimes all you need to do is open the case, replace the battery and the tablet will start.
Dec 09, 2015 | Tablets & eReaders
MY TABLET VIDAO V7TAB8KB BLOQUADA I NEED THIS USER AND PASSWORD
The password is set by the owner. Ask the owner.
Aug 21, 2015 | Tablets & eReaders
How unlock pattern lock on proscan tablet PLT9602G
Hello Heather
You were supposed to remember the pattern you gave it when you locked it. That's why they have the Lock. To keep unauthorised people out.
Give it the right pattern is all I can suggest!
Mar 02, 2015 | Tablets & eReaders
How do i get my tablet screento rotate
What type of tablet? If it's an iPad this is available a few different ways.
If it's an iPad 1 running on iOS5:
1. Check the little toggle switch on the side, depending on your settings this functions as both a mute and a rotation lock. Try changing this.
2. If your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Double click the home button and when the little menu pops up swipe right on it, you should see an option to lock/unlock the rotation.
If you are on a newer iPad
2. f your toggle was set as a mute control and not a screen lock then the screen lock is kind of hidden. Swipe up from the bottom of the screen to access the control panel. The screen lock/unlock option is directly on the control panel.
Dec 11, 2014 | Tablets & eReaders
How can I get the screen to rotate over to the correct position?
You might have your Orientation Lock on. If you are using iOS 7 or 8, swipe up from the bottom and disable Orientation Lock (http://cdn.osxdaily.com/wp-content/uploads/2013/10/stop-screen-rotation-orientation-lock-ios-7.jpg)
Alternately, the switch on the side of your iPad might be set to Lock Rotation, so go to Settings > General and see if Use Side Switch To: is set to Lock Rotation. This would mean that whenever the switch above the volume controls is down, the orientation is locked.
Sep 30, 2014 | Apple iPad Tablets & eReaders
Reset 4 digit lock code for iPad 2
Hi John,
If you cannot remember your lock code, you will need to restore your device as new or be able to restore a backup if you cannot remember your lock code.
If you do remember your lock code you can update it in the settings app:
Click on Settings and then scroll down to the Passcode option (you may have to scroll down a bit). This will bring you to the Passcode Lock menu where you can turn off or update your lock code.
Hope that helps!
Aug 05, 2014 | Apple iPad 2 Wifi 16GB
Forgot Password to Parental Lock app
I can lock up my Facebook, WhatsApp, Clash of Clans, Messenger, Gallery and other important apps which may leak your privacy with LEO Privacy. And I can also customize my lock mode which allows me to lock different apps under different circumstances. it is really an smart applock, you will never worry about forgetting password. LEO Privacy Applock Boost Hide Android Apps on Google Play
Aug 16, 2013 | ASUS Transformer Tf300t Tablet
Screen rotation lock is now audio muting. i want to return to screen rotation lock
Unfortunately, this is a new feature from a past update. There is no current way to change the lock button back. However, you can access the screen rotation lock by double clicking home, swiping right, and toggle the screen rotation lock. As a future note, in the next update, you will be able to change it back.
Feb 25, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
57 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
