Question about JVC HD-52G786 52" Rear Projection HDTV
No picture and ticking noise - JVC HD-52G786 52" Rear Projection HDTV
1994 saturn when trying to give it gas, it makes a ticking noise and a loud pop sound what is going on
You installed the wires wrong
Google a picture of the ignition
wires & firing order
keep in mind exhaust converters get blocked
after 12 years or sooner if you have cylinder misfires
Aug 13, 2014 | Cars & Trucks
There is a ticking noise when moving
The ticking noise could be coming from a CV joint. Does the ticking noise go away in reverse? A loose brake pad (Anti rattle clip missing or broken) will move back and forth in it's mounting, a warped rotor will enhance this effect, the ticking noise will come when the pads moves upward into it's mounting causing a metal on metal tick.
Does the ticking noise get louder when you are turning the vehicle? If it does this would indicate a worn CV joint.
Apr 04, 2013 | 2006 Ford F-150
There is no picture and there is a tick tick ticking noise coming from inside the TV
The ticdk tick sound is probably the switched mode power supply making noise due to the fact that there is a shorted component inside(may be the horiz. output transistor). You may need to have service personell look at unit and get an estimate...this is older set n may not be worth repair
Jan 14, 2011 | Panasonic PT-51HX40 51" Rear Projection...
AKAI PT5492S - Makes a ticking noise,black
This usually is indicative of the EXTREMELY HIGH VOLTAGE anode connection somewhere between the flyback transformer and one or more of the crt picture tubes or the splitter. Being that this circuit has a running voltage potential of over 30,000 volts if you are not familiar with these YOU CAN BE KILLED messing with it!!! What happens is that there is a breakdown of insulation over time usually from dirt or other environmental contamination. Usually a good cleaning and replacing the HV anode wire that has failed. (hint) it will be the one that the "ticking noise" is coming from. The ticking noise is actually the high voltage arcing to the chassis/ground.
Be careful!!!!
Dec 27, 2009 | Akai PT5492S 54" Rear Projection...
I have a 1998 GMC k1500 and it makes a ticking noise eveytime u step on the gas?
WORN PISTON RINGS MAKE A TICKING NOISE.VALVE LIFTERS MAKE TICKING NOISE.WORN DISTRIBUTOR SHAFT BUSHINGS MAKE A TICKING LIKE NOISE.
Oct 29, 2009 | 1998 Chevrolet K1500
NO PICTURE BEEPING NOISE
I have an RCA projection TV P52939 it has no picture, and makes a beeping or ticking sound can you tell me what it is.Thank you
Apr 20, 2009 | Televison & Video
Picture and a ticking noise from behind the television
ticking sound is hv shut down. electronic sweep circuit or power supply problem. need tech.
Dec 04, 2008 | Philips Magnavox TS3260C 32" TV
Green flashing power light and ticking noise but wont turn on
Did you touch the Lamp? If you did it may have blown. the color wheel may be the problem or yes the balist
Jul 25, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the partstore.com ...............T.
Jan 15, 2008 | Emerson EWF2703 27" TV
Plasma Tvs
When switching to STBY raster remains and buzz noise is heared from the speakers
Cause: +B voltage (103 V) does not switch-off. Remedy: Replace defective C541
Ticking noise and line in picture
Transistor 7381 (BC848C) defective when hot
Dead with ticking noise from line
Replaced C622, C604 and Q509
Nov 26, 2007 | Televison & Video
JVC HD-52G786 52" Rear Projection HDTV Logo
12 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
