Question about John Deere 4020 Gas & Diesel Tractor Radiator
Pto isn't kicking in on my john Deere la 175, 26. Hp mower, I replaced the clutch and it still isn't kicking a in.
Pto just quit working, motor bogs down when pto is engaged, replaced clutch and it still bogs down when pto switch is pulled.
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
lester482529
  • 226 Answers
SOURCE: Engine starts and runs Great. When I engage the
at the point of lowering the pto it's trying tosuck more air to mix with the gas .you might just need to change the air filter.
Posted on Jun 07, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
wadembly
  • 462 Answers
SOURCE: The mower blades on my John Deere stx 38 lawn
it sounds like the safety switch under seat is bad
Posted on Jun 28, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
I have a John Deere 870, and the PTO quit working, first of all, the pto quit letting the mower deck go down then it quit working?
check your fluid level for the hydraulics and look and check that the pto rods are connected and adjusted correctly
Jul 31, 2016 | John Deere Garden
Wiring diagram for LX172 John Deere
Type into google john deere riding mower wiring diagram for pto switch clutch circuit then click images
May 12, 2016 | John Deere Garden
I have a Z425 John Deere will not kick on blades PTO
Check the electric PTO clutch coil resistance should be around 1.7 to 2.5 Ohms. If not within this then it is bad. If okay work your way back to the PTO switch and ignition switch checking for voltage as you go. Where the voltage drops out is probably the source of the problem.
Apr 12, 2015 | John Deere Garden
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be needed...is the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Pto wont engage
If you have power, AND GROND to your PTO clutch, and it isn't engaging. Then you need a new clutch!
May 30, 2012 | John Deere Garden
John Deere 4020 Gas & Diesel Tractor Radiator Logo
42 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
