Question about Hobart Dishwashers
Sr24H won't turn off, any suggestions?
The Hobart SR24H will not turn off, just keeps cycling, any suggestions as to what the problem might be?
  • 109 Answers
SOURCE: i have a hobart sr24h
It may be the wash impeller disk broke off, and cut into the bodywash pump housing. Remove the 8 screws(4 long into the posts and 4 short, into the lower cover) to remove the wash arm support. Look each side of the wash impeller on the lower housing for a slot cut, Check the wash arms for small pieces of grey plastic from the impeller disk.. Make sure the fill flow rate is 20 PSI. If your water is hard, the booster and vacuum breaker may be restricted with lime buildup. Remove and clean as required,
Posted on Aug 03, 2009
  • 110 Answers
SOURCE: Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Posted on Jan 11, 2010
  • 49 Answers
SOURCE: We have a hobart sr24h dishwasher which is leaking
hobartcorp.com under service tab click parts then smart parts system tab
Posted on Jan 29, 2010
  • 110 Answers
SOURCE: sr24h dishwasher will not heat water, we have 110
if you have voltage to bstr. contactor coil and contactor is not pulling in the coil must be bad on the contactor. try pushing in thecont. manually to see it is not bound up mechcanically, if you can do that replace bstr cont. because the coil is open. dont forget to vote, monomoy
Posted on Mar 01, 2010
  • 86 Answers
SOURCE: my sr24h hobart undercounter dishwasher is stuck
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
Posted on Sep 19, 2010
I am working on a Hobart SR24H dishwasher. The cycle starts but the fill valves are not energized and no water is being allowed into the system. The hot water booster tank is heating up.
Hello Jim Richards,
I tried to pull down... any meaningful information
from the GARDEN VARIETY part houses...
It appears you can get replacement parts through grainger...
Manualslib.com does indeed show SR24H
a commercial grade unit...
(also SR24C... similar chem clean commercial grade)
Hobart SR24C Instruction Manual Page 4
Hoping to find valves, schematics & perhaps
even PART NUMBERS... (no luck).
Found some parts on the internet...
Parts list (Rev A, August 2009)
http://www.hobart.com.mx/pdf/CatPartes/F43078RevA_Lk.pdf
I don't know if you have tried to "activate" the valves
(power direct to... VALVES not responding = open coil)
Or you are having a control board failure
(test for voltage present)...
If you have power at the valves... and they are merely not responding... Some folks will tell you to clean the
(descale.... decalcify) your VALVES.
I'd say replace them... NOT CHEAP
(but it appears "KITS" might be available)
then play with the old ones at your leisure...
(obviously... if that I indeed your issue)
Grainger.com might help (but not obvious on the net)
Heritage parts, WhaleyFoodService and Partstown
(appliancepartspros was a COMPLETE BUST)
see below
https://www.bing.com/search?q=hobart+sr24h+parts&form=EDGEAR&qs=PF&cvid=dc8dfce20e70486cbcb3a4149b58c984&cc=US&setlang=en-US&PC=DCTE
Whaley
Parts Manual HOBART SR24H
Oct 12, 2017 | Hobart Dishwashers
Hobart SR24H dishwasher after rinse cycle the same time pampas water in and out of the dishwasher, two pipes are opened and working
Hello.
As per my personal opinion this is normal because for the final rinse you have a small booster or boiler..
When you turn on the machine..it starts fill and also the booster for the final rinse.
You start the machine..wash cycle...rinse cycle..
Now..new water(from rinse booster) is coming on the tank in order to rinse the dishes..on the same time the machine drains the excces water from the rinse(over flowing) and fills up the booster with new water.
Should be like this
Good luck
Jun 29, 2013 | Dishwashers
Hobart sr24h; It is doing a double cycle; runs a compleat wash and rince cycle stops then 30 sec later start over so our normal 3 min clean now takes 7 min to fully stop operating. What could be the cause...
Thats easy....Change your timer !! The timer turns 180 degrees for one cycle .Then 180 degrees for another cycle thus completing a 360 degree rotation . One side of the timer appears to be broken.
Sep 17, 2011 | Hobart SR24-H Built-in Dishwasher
My sr24h hobart undercounter dishwasher is stuck in a mode where all it does is drain water out. Will not do anything else...???
Sep 19, 2010 | Hobart SR24-H Built-in Dishwasher
Jan 10, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Sr24h dishwasher will not heat water, we have 110 volts to contacts but they will not close in cycle to turn on heater?
Apr 22, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
87 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
