Question about Roomba iRobot Verro 500 Pool Cleaning Robot
Verro 500 Doesn't Move
We just reopened our pool. Plugged in the unit put it in the pool and nothing is moving. There is power to the main unit because the light is comes on... however after a few minutes of no movement the power shuts off.
Will not move. has power when key is on. everything else works, but it just won't move.
Timothy,
What type of unit are you referring to? If you put in the make and model, they did not come through with your question. Most vacuums do not come with a key unless you are talking about a big commercial unit.
Jul 29, 2015 | Vacuums
How do I get a polaris sweep tail to work
A 360 works off of the main pool circulation systems return line.
Is the pool pump on?
Is this a pool/spa combo?
If so, then is the water returning to the pool or the spa? It should not be returning to the spa, dial it back some.
Is water coming out of the dedicated inlet fitting that feeds the 360?
If not, find out why, this is the problem.
If there is water flowing out of this fitting, then the pool sweep itself has something stuck in the drive axle or in the drive wheels.
You could also have "Stripped" gears/teeth on the the 2 front drive wheels, if smooth, (if sections of the two front wheels are smooth where there should be teeth), then replace them.
Take a look at the pic below, you should be able to see the teeth on the inside of the wheel.
Good Luck
Feb 21, 2015 | Polaris 360 Pool Cleaner 360
Brush doesn't move
Your belt is broken and needs to be replaced. Turn this brush side up. Unscrew the cover plate and you will see where the belt goes. Pull out roller, put on new belt, put back together and there you go.
Oct 07, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
My rain vaccum
Need more information...Are you having problem with Main unit or the power nozzle? You can also call and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Oct 07, 2012 | Rainbow E series Canister Wet/Dry Vacuum
Power nozzle N106M on our Electrolux Guardian has stopped workin
Start simplest always and work back to most difficult... so make sure you have power to the main unit, do you have a cheap voltmeter? If not they're cheap... Second check that connection plug is not stuffed with debris. Point is isolate whether it is the unit or attachment, most likely it's in the connection and repairable by you or used vacuum repair.
Aug 04, 2017 | Electrolux Guardian Bagged Canister Vacuum
Non-working Electrolux Centralux vacuum system
Is there a small LED light illuminated where the low voltage wires connect to the main unit? There may be a small rubber boot covering the connection and the light. Just slide it back, and there should be a green LED light if the unit has power. If the LED is not on, there is no power to the unit (tripped breaker, plug came loose from electrical outlet, etc.) If LED is illuminated, short across the pins where the low voltage wires connect to the main unit. (These will be small 18-22 gauge wires, not the larger electrical cable!) You can do this with a coin. (Don't worry, it's just 24 volts and you won't even feel it) The unit should come on. If it doesn't, and you have light from the LED, then it's probably the relay on the board inside the unit, or the motor. Good Luck!
Nov 14, 2008 | Electrolux Centralux Vacuum
Brushes not spinning after change out
I got my brushes spinning by moving them while the unit was running. For mine it seems that they got stuck from sitting. The brushes move from the air driven motor unit. This works from the vacumm that is being put through the machine. I just spun the brushes while the unit was turned on. Don't get your fingers caught.
Oct 26, 2007 | Hoover F5906-900 Upright Steam Vacuum
Roomba iRobot Verro 500 Pool Cleaning Robot Logo
90 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
