Question about Cuckoo Rice Cooker Cr-0631f
Cukcoo rice cooker unlock would not turn off - Cuckoo Rice Cooker Cr-0631f
I need the recipe for cooking rice in Crystalia Steamer/Rice Cooker
The general rule for cooking rice whether its in a rice cooker or a deep pan is to rinse the rice three times, put the same amount of water in the cooker (1 cup water to 1 cup rice). Turn on the cooker, let the rice cooker complete its cycle. Let the rice sit in the cooker for 10-15 minutes to steam. Serve.
You can vary the amount of water depending upon whether you want drier or moister rice. Enjoy.
May 30, 2011 | Microwave Ovens
I have rice cooker i cant cook rice.i am on the cooker 5minute going tourn off
U mean, the rice cooker turns OFF after 5minutes?
Sounds like THERMAL adjustment needed!
Nov 05, 2010 | Aroma ARC-717G 14-Cup Rice Cooker
Rice cooker not turning on
There is a sensor that regulates how hot the cooker gets and shuts it down to the warm setting when it senses that the heat is too high...meaning that all the water has cooked off....my guess is that the sensor failed and as far as I know it is not replaceable.
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Jun 30, 2010 | Breville RC2 10-Cup Rice Cooker
The white rice turns brown and it smells after only 2 or 3 days.
Nothing. Cooked rice should be immediately refrigerated if not used and used within a couple of days, to do otherwise can be fatal.
Your cooked rice is discolouring due to either bacterial or fungal growth, either due to remaining spores in the cooker between each load, or just due to environmental effects. So far, you've been extremely lucky not to suffer very severe food poisoning.
I suggest that you click here for further advice (.pdf advisory document)
May 25, 2010 | Tiger JNP-1500 8-Cup Rice Cooker
Purchased Durabrand Rice Cooker model HRC 18G working fine Is there a User manual for this cooker? All that is needed is ratio of water to rice including plain long grain and Basmati rice for 1 - 4...
Instructions quoted from the Durabrand Rice Cooker model HRC 18G manual...... 1 cup of uncooked rice rice will make about 2 cups of cooked rice. Add rice to the inner pot. Maximum four cups uncooked rice for the model. Many varieties of rice can be used including basmati, wild rice, arborio risotto, saffron rice and long grain rice. Whole grains, such as barley can also be prepared with the rice cooker, follow instructions on the package.
For every cup (160ml) of raw rice, add 1-1/2cups of water. For stickier rice add slightly more water, for fluffier rice use slightly less water.
When your rice is cooked, the cooker will automatically switch to the warm function and the yellow warm light will turn on. The cooker will stay in the warm function untill is disconnected from the wall outlet. The cooker will keep the rice warm 158F - 212F
Hope this helps, its quoted right out of the manual I have for my cooker
Jul 27, 2009 | Kitchen Ranges
My rice cooker is scorching on the bottom.
You need to make sure you have enough water in there. When the rice is cooking, it is sucking up all that water so it can cook and expand. If you don't put enough water in the rice cooker, the rice will use up all the water and then if there is no water left, it will start burning the bottom of the rice because there is no more water.
Hope that helps :)
Mar 07, 2009 | Maximatic ERC-003ST Elite Gourmet 3-Cup...
Rice cooker keep feature turns rice crispy
This sounds like the thermostat inside the unit has went out and is overheating whitch in turn is cooking your rice too fast and too hot! if the thermostat is replaced it will cook the rice even again!
Please rate my response to your question
Thank You!
Jan 07, 2009 | Sanyo ECJ-PX50S 5-Cup Rice Cooker
Digital oster 20 cup capacity rice cooker wont turn on
Rice cookers will only cook if you have enough water in it. If all the water has cooked out, then the cooker will turn off. Remember when you put your rice in the cooker, make sure you level it off. Then add twice as much water so that it will over cover the rice.
Nov 18, 2008 | Oster 3072 20-Cup Rice Cooker
Water and rice
the ratio is 1:1.
4 cups rice = 4 cups water.
be sure to turn the rice cooker on. just wait for it to say cook!
have a delicious rice meal!
Dec 18, 2007 | Town Food Service 57155 55-Cup Rice Cooker
Rice burning at bottom of cooker
Your cooker, along with mine, cooks very hot. If it is new then you can take it back, but if you want to cook with it then you need to stir the rice often. About every 5 minutes should be good. As soon as it is done you need to remove it from the cooker. Let's see how that works.
Aug 30, 2007 | Oster 4724 Rice Cooker
Cuckoo Rice Cooker Cr-0631f Logo
24 people viewed this question
Top Cuckoo Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Cuckoo Kitchen Appliances - Other Expert? Answer questions, earn points and help others
