Question about Mtd 19 In. 173 CC OHV 3-In-1
Cub cadet spark plug boot - Mtd 19 In. 173 CC OHV 3-In-1
Cub Cadet will not start Has gas,oil,spark and fuel is pumping to carb
Have you checked for spark at the spark plug, do that and report back.
Apr 26, 2017 | Cub Cadet Garden
I need to know the location of the spark plug on my Cub Cadet GT 2550. I need to replace it.
They are on each cylinder head. There is a wire from the coil to each spark plug. Remove the wire and you'll see the spark plug
Mar 29, 2017 | Cub Cadet Garden
Where is the spark plug on a cub cadet 1040lt
OPen the hood and you will see it. Link to owner's manual at cub cadet. see page 21: http://www.cubcadet.info/Manuels/2007/1000-SERIES-LT/OWNERS/LT1040_13AX10CG710_Ow_07.pdf
Jul 26, 2014 | Cub Cadet Garden
CUB CADET RIDING MOWER HAS NO spark TO PLUGS
For some reason, our Cub Cadet riding mower 1046 will not start. The battery is o.k. Where are the spark plugs? What could be wrong with it?
Aug 15, 2012 | Cub Cadet Garden
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
No Spark - Cub Cadet model 71 with a Kohler 8hp
check condition of the magneto,located under the flywheel
Oct 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
2160 cub cadet that wont start.hot spark to the plugs
You've solved for some of the equation. Spark. Fuel. Air.....all in the proper sequence. Now, what condition are the plugs ? I'd change them out if they have any wetness to them. Check your fuses as well. Another thing is the 'safety switches' - located in seat, on parking brake, etc. One of these could have come undone or gone bad/loose wire. I'm thinking the latter....
Jun 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Mtd 19 In. 173 CC OHV 3-In-1 Logo
19 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
