Question about LG RZ32LZ55 32 in. HD-Ready LCD Television
Retune someone gave me this tv, but i can't retune it.
How do I channel auto scan
in most tv'd there is as a channel retune option from pressing the menu button and selecting setup and then selecting retune. In retune menu there would be a manual retune or an auto retune option.
Karen if you provided the Make and model number of your particular television someone o fix ya could find the user manual most likely and give more precise instructions on how to do this.
Dec 31, 2014 | Televison & Video
How to retune tv programmes tv telling me to retune but i cannot access instructions on tv?
Depending on the TV model, if you do not have the instructions for the TV/remote, you may just have to play around with the options via the remote and find the choice for retuning the stations.
Sep 18, 2014 | Televison & Video
Mitsubishi cold 3.0 v6 workshop manuals
If your philips tv keeps losing it's stations when you switch it off, this my be a solution -----my 42" tv would need to be retuned every time I wanted to watch it this fault just started over night it was all working fine then sat down to watch tv and had to retune tv from scratch I could then watch telly all night fine change channels no probs all great switch it off next day retune and so it went on if you have this problem switch telly on then hold in menu button on tv until screen goes black (this reboots software) then retune tv as normal it will ask if you want a full retune (yes) when this is complete digital and analogue your tv should now remember channels when switched off and work as it used to ----( Hope this helps you if you have had this problem it worked for me ). Good Luck
May 29, 2014 | Televison & Video
My 19ld350 lost signal and will not retune
If the video inputs still work, give it to someone for use with a satellite, cable box, video games, dvd, etc. but if it truly needs a tuner, a 19" TV is usually not worth a main board replacement.
Feb 15, 2014 | LG 19LD350 19Inch 720p 60Hz LCD HDTV 19 in...
TV will not change or show channels
You don't say whether you have had it working at that location before. When you move a TV between houses, it is necessary to retune your channels. Would recommend returning to first time installation.
If you haven't moved it recently there are other reasons why this might happen. 1) There is damage to your aerial caused by weather, 2) A power surge or loss of power to the memory battery on your video board has wiped the frequency information from the memory [the memory battery is like a watch battery that keeps a small amount of power going through the system to it can keep your settings when unplugged], 3) The internal tuner board for your TV has packed in.
If '1' is the case, obviously you need your aerial fixed; if '2' is the case you need to retune again [you'll know if the battery is dead if you have to retune every time you turn on the TV]; if '3' is the case you either need a replacement AV board or someone to solder a replacement tuner board to it.
Jun 17, 2013 | Philips Phillips 40 in. LCD HDTV
How to retune Panasonic viera
Return to the initial setup procedure and let your TV search for active channels. If you do not get results, you may not have the necessary antenna for signals to be detected
Jun 10, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
After retune no bbc 1 2 bbc news channels tv with
Sounds like you haven't retuned the set correctly. Use the factory settings/ default setting if poss. Look out for too much signal if you are on a booster.
Nov 06, 2009 | Pace Televison & Video
Loss of BBC channels
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Philips TV Tuner Video Capture PCI Card -...
Problem retuning syncmaster 933hd tv
Oct 01, 2009 | LG W2353V-PF 23' LCD Monitor
Samsung hd flatscreen
problem solved just gave him his glasses ha ha many thanks
Oct 01, 2009 | Televison & Video
LG RZ32LZ55 32 in. HD-Ready LCD Television Logo
Computer Repairing
Computer Repairing
