Question about Lionel New Haven Freight Train Set
Running a conventional Lionel Engine with a Cab 2 Legacy remote:
I am presently running two seperate tracks or layouts. The one is a complete Legacy cab 2 remote system with a Legacy diesel engine, it runs great. the other layout has a conventional steam Polar Express engine with a proto sound coal tender. I am presently trying to run the conventional Polar Express train with the Legacy cab 2 remote system. Nobody, even the dealer cannot tell me exactly what I need to make the conventional system work with my Legacy remote system. so far I have invested in a Powerhouse 180 watt transformer #6-23983 and a new Powermaster Bridge #996 #6-24279 and the way it looks, I will need a #6-24130 TMCC Powermaster variable track voltage unit. I saw some instruction about using the three ended communications cable that came with my cab 2 Legacy system to be connected between the cab 2 base unit, the Poermaster Bridge unit and the TMCC powermaster. I see no connection point to connect the communications cable to the Tmcc Powermaster unit? You would think Lionel would make it a little easier to run a conventional train with a new Legacy cab 2 remote system. What else would I need & how do I connect it??
Signed: Confused & wiring nightmare!
    Brigadier General:
  • 3,917 Answers
Please check out the following websites which explains the accessories required to run the Legacy Cab2 remote system .
http://www.legacystation.com/Lionel-TMCC-Legacy.htm
and
http://www.legacystation.com/Lionel_Trains.htm
Also a FAQ document would be usefull while trying to work with it:
http://www.legacyinfo.net/LegacyFAQ.pdf
Thanks for contacting Fixya.
Posted on Jun 18, 2009
  • edoptician Jan 26, 2014
    Alternative Electric Railroad Company has all of the goodies to make your Polar Express locomotive a TMCC locomotive. Im not sure if you want to go down this road
Lionel 6-30218 not working,The engine is making hissing sound the headlight bulb is glowing the cab cars have light ,The remote Red Light is glowing when turnig the knob of throttle to right & lef
Your best option is to contact Lionel Customer service:
598-949-4100 ext. 2
9AM - 5PM Eastern Time Zone
They will give you instructions if they think it needs to be sent in for repair.
Jun 02, 2014 | Lionel A Christmas Story Gauge Train Set...
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Apr 05, 2014 | Lionel Crafts & Hobbies
The layout fits totally within a 4x8 board. No accessories and only the engine on the track. The engine stops like it is getting little or no power.
First check your track with a multimeter for track power voltage & continuity.
Second, clean your wheels & pick up roller on your locomotive.
Third, clean your track.
Oct 20, 2013 | Lionel Cw 80 Transformer
We are running the legacy control system. Our layout has roughly 200 feet of track. There is one stretch about 2 foot long that the engine seems to lose its signal. Imparticular the union pacific big...
Check your track voltage with a multimeter. If you get a lower reading at the spot that causes the problem, add a feeder wire to that point.
Oct 04, 2013 | Crafts & Hobbies
Legacy w/ flyer, using a capasitor between both tracks.can you do this twice on the layout?
Yes you can, three or four times before you would need to alter the value of the capacitors to allow for the parallel effect electrically.
Jun 17, 2012 | Lionel 14295 990 LEGACY Command Set V2
I have a new legacy 990 which does not seem to communicate with the engines. How can this be reparied?
easy. if the train switches are not set up correctly, they will cause problems. if the train comes on, but does not move, switch to cab-1 and set which engine you want. if it does not move, but the rpm goes up and down with the dial, CHECK THE BRAKE! if none turn on, check the voltage in the transformer, grey box, and track. if none of these help, please contact me. Hope it helps!
Dec 24, 2010 | Lionel 14295 990 LEGACY Command Set V2
I have a lionel legacy cab-2 remote i hooked up every thing to the manual but when i turn it on i dont get any track power
just unplug the transformer from the grey box (the one with the green light and red light) and check the voltage. if it doesn't read anything, try unplugging the transformer from the outlet and plugging it back in again. if you get a reading, replug the transformer to the grey box and check the voltage of the silver screws (where you put the + and - wires from the track to) and try using the train again
May 30, 2010 | Lionel 14295 990 LEGACY Command Set V2
WE are trying to get our lionel holiday train going. Is there an on/off switch on the train? the part that goes on the track is lit up but when we puch the remote control with train on the track nothing...
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Dec 23, 2009 | Lionel Trains Holiday Express G Gauge...
Lionel New Haven Freight Train Set Logo
1,102 people viewed this question
Top Lionel Crafts & Hobbies Experts
Jeff Hogancamp
Jeff Hogancamp
ray gallant
Traindoc
Level 1 Expert
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
