Question about Ovation Music
Red battery light is staying on with OP-Pro
New battery already installed
No sound third octave on korg trinity pro x 88 keys
After gaining access to the inside- carefully remove the ribbon connectors (plugs) and reseat them. If that doesn't help have a tech. look for bad op amp.
Jan 11, 2015 | Korg Music
My line 6 lowdown 750 keeps cutting out when i play a low b on my bass
Protective circuits kicking in. You may be overdriving the preamp to a clipping condition the amp sees as a problem. If it is under warranty, contact Line 6 and see if this is normal for this amp. It should not be, but you never can be sure.
Apr 26, 2012 | Line 6 Music
I have an Ovation Celebrity Koa with the OP-30 system in it. When I plug it in, I don't always get sound. I changed the battery, and have a new patch cord. Can someone help me?
where the socket is for the cord to be plugged in, often the ground will come loose or break on the socket connection, you will need to take off the plate that conceals the electronics of the guitar and see if any wires have become damaged , this happens a lot when your using a patch cord with a 90 degree end going into the guitar , it puts added pressure on a already touchy socket.
Sep 01, 2011 | Ovation Ck047 Celebrity Acoustic Electric...
I need know; what is the componnet OP1 (R3B 303)? thanks,,,
Look for numbers on the chip... It appears that in other gear that I can get schematics for Focusrite likes the NE5532 and the NE 5534 chips for op amp service.
Jul 15, 2011 | Focusrite Twintrak Pro
Sk 100 body pack transmitter does not seem to be transmitting. Red or Bat light stays on constantly even with a new battery installed. Any quick fixes? How about schematics? Dan
Reading the instruction manual, the red LED is used for more than one thing. I suspect the unit may be either not synced with the reciever frequency chosen or in one of the mute modes. I would re-read the setup mode for this unit as the SK 100G3 is a bit more complex than many for setup.
If the light won't go off when you open the battery cover and press the button to turn it off following the procedure, then there is a problem. I would go through the COMPLETE initial setup of the unit from scratch. Schematics are non-existent for most of this and would not do you much good anyway as the circuit boards will all be surface mounted with some parts the size of a grain of salt. Also a lot of the RF will be under soldered on shield covers. Repair of these would be a factory job if they even do it. If you have ever opened a cell phone, that will be comparable.
May 08, 2011 | Sennheiser SK 100 G3 Mic Wireless UHF
Is the red light indicator ment to stay on all the time when playing, or is this a warning light to let me know that the battery is low .Thanks and kind regards Neil
Simple test to try: Put in a brand new battery... If light goes out, then it is a low battery warning.
HOWEVER, it is likely a warning that battery is on so you don't forget to turn it off when done. Tried to find manual for it and could not. Your manual should tell about it.
Mar 14, 2011 | Ovation MM68-CCB Acoustic Electric...
Hello! I recently bought used Behringer EQ 700, but it's not working. Baterry is ok, the red ligh is burning, when I press the pedal, but no sound is coming through, even when its not on. What could be...
The red light means NOTHING regarding the battery condition... If battery is not new, try a new one.
I have seen several problems... some people get the cables backwards for input and output. The INPUT cable is what turns on the battery and it has to be a mono cable.
ANOTHER common problem with ABUSED pedals is that the jack used for external power adapter gets smashed at some point and cracks the circuit board near it. USUALLY the light will not come on when this happens.
Byond this, it probably requires repair. Some are easy to open and others are a bear to get the circuit board out... key is to NOT force very much when working on these.
Feb 09, 2011 | Behringer BEQ700 Bass Graphic Equalizer
Music Logo
Top Ovation Music Experts
Computer Links
ray gallant
rhodesworks
Are you an Ovation Music Expert? Answer questions, earn points and help others
