Question about Creative Labs Inspire 4400 Computer Speakers
How to resoldering the volume colors - Creative Labs Inspire 4400 Computer Speakers
Our tv keeps changing colours to blue red and green
Your television have color problem.That symptom is cause of loose connection or cold solder in chroma section and color output driver transistor of CRT board of your television.You can fix that problem by resoldering the chroma section and crt socket section of your TV.first thing to do is open or remove the back cover of your TV,then you can see the crt board connected to picture tube.Resolder that parts,specially the color output transistor the red,green and blue driver.Resolder also the chroma section.You can see the jungle ic,thats the color ic.Make sure that there's no short circuit when soldering the PCB board.After the resoldering turn on the TV and check if color is normal.Thanks..
Aug 26, 2011 | Televison & Video
Tip
Wiring For Volume and Power Switch
I ripped the cord off the external thing-a-ma-bob for the volume and power switch on the Maxell Flat Speakers with Subwoofer unit, but managed to figure out which color wires attach to each numbered contact on the small circuit board inside the unit. The board has labeled contacts from 1 through 9, and following is the map for each color wire:
1 = Black (large wire, ground)  2 = Red 3 = Brown 4 = Orange 5 = Yellow 6 = Green 7 = Blue 8 = White 9 = Black (small wire)
I resoldered each wire back to the little board and it works like new. Much better than throwing them out and getting new ones, because these speakers have a decent sound and take up very little room.
I hope this helps anyone who runs into the same situation, because I was unable to find this information anywhere else and had to figure it out by trial and error.
on Sep 04, 2008 | Maxell Flat Speakers With Subwoofer and...
The tv screen has gone pink. no other clor, just pink.
Tv have 3 colors guns like R,G,B colors.Tv is missing one of it color gun.Have a soldering iron and a roll of solders? Take the tv aparts,resolders the video board soket pins holes that connected to the CRT-(tv tube).Resolder the Yoke wires like R,G,B connected to the main board too.Will solved this problems.
Mar 16, 2011 | Curtis-Mathis CM32010 TV
Vs-60609 my color is gone just black &white what might be the problem
The color crystal may have a bad ground and needs resoldered. But that is not the only solution. You will have pull the convergence board out and rework this. I mean you will have many, many bad grounds here.Start with the convergence board, IC STK 393-110 needs resoldering, replace capacitor (location number and value of capacitor) C8C05 25 volt 100Mf,C807 25 volts 100MF, C2C86 25volts 10 Mf, C2V17 25 volts 10Mf and C601 350 volts 1 Mf. Also resolder jumper cable socket pins behind the tuners, TU1A02 (says RF). Resolder jumper sockets CE,RG,DM, VU, DP, EL,PM, PF.Other socket connections include KC, KB, AV1, AV2. Resolder IC 2P30. All of these are located on the signal board. This board has all of your RCA and RF connections. Next remove the power supply board. This one has the flyback transformer, solder the connections on the transformer as needed. Resolder jumper connections DM, DT. Diode 983 will need resoldered and the resistor( R522) is running hot and the colored stripes are all gray. Replace this resistor with a .82 ohm at 2 watts. Replace capacitor C935 which is a 35 volt at 47Mf, this one is bad. Check capacitors C551 and C531 which are 160 volts at 2.2Mf. They are mostly OK but can go bad any time now. Q533 is a high speed switch it may be good, you should resolder this. The cross for this would be a NTE 2361. I don't believe this one is bad. Leave the original. and resolder the Horizontal transistors Q5A02 and Q5A00. Also, there is a capacitor next to the high speed transistor switch (Q533) that may be weak by now. I don't know the value off hand, only that it is near the Q533 transistor. It is an electrolytic (looks like a miniature can). Well there is a lot to consider, but this TV will operate for a few more years. Find a hobbiest or TV tech to do this if you can not. I know, its a lot, to return the color on your TV, but this is what it will take.Show them this note. Thanks for asking and show a few hands of support.
Feb 21, 2011 | Mitsubishi Televison & Video
My sony 29'' color tv turned black and white.color sometimes flash on the screen.video and sound is normal.pls help
     If your TV colors get black and white with flickering then there must be a problem of cold soldering(Loosing) and it can be remove from resold, Resold in video section and problem will be solved.
     Thanks.
Jan 14, 2010 | Sony Televison & Video
Sony kv-36fv27 color is bad.
Know to solders?Resolder ur video board socket holes that connected to( CRT tv Tube).Resolders the Yoke cable red, green,yellow connected to the main board also.Should get colors back,if the colors IC on the video in not dead,and capacitors help the IC on the video board.
Dec 19, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
I have lost the color on my flat sceen tv, A sylvania.
This is a cold solder problem in CRT board you must resolder all parts joint there and also resolder the "crystal"joint parts near the jungle IC.If you already resolder this it works normal again.
Hope this may help you;
Regards,
VOTIT
Oct 10, 2008 | Televison & Video
Sony tv
Please resold all pins of IC001 in main board of TV. Problem will be solved.
Aug 08, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Flashing color in and out with popping sound
This sounds like the solder joints have cracked on the AFT can inside the tuner, a common Sony problem. Removing the tuner, opening it up and resoldering the grounds and small transformers inside should clear it up.
Jun 26, 2007 | Sony KP-43HT20 43" Rear Projection...
Screen changes from normal to green instantly
intermittent problem resolder around the color circuit.good luck.
May 17, 2007 | Sharp 27H-S60 TV
Creative Labs Inspire 4400 Computer Speakers Logo
60 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
