Question about DHD Car Audio & Video
No light on amp
Just installed, think ive got everything hooked up right but im not sure how to check
  • 33 Answers
SOURCE: mtx 895 trouble
check your fuse up front first. some amps will turn the light on with only the remote wire (the 12 volt signal from the head unit). That may be your issue. If not you need to check your signal input. try hooking the rca's to a diffrent source, i.e. other radio your tv anything with Rca out put. If still you get nothing then pull your subs out and take a regular 9 volt battery and touch the leads to the positive and negative of the sub. Just for a moment though if the subs move when they come in contact with the charge from the battery then my last suggestion would be to take it to a store where you can have an authorized tech check out the equiptment. Good luck
Posted on Nov 20, 2007
  • 631 Answers
SOURCE: Red light on the amp.
Have you checked your speakers to make sure they're connected to the amp (a wire could have broken or pulled loose)?
Have you confirmed that you have a good signal reaching the amp?
The red light isn't always a good indicator that the amp is functioning properly. If you have speakers connected to the amp and have a good signal feeding the amp, the amp may have failed.
Posted on Dec 23, 2007
foskorider
  • 79 Answers
SOURCE: performance teknique icbm-782 amplifier will not power on
run 12 volt into your rem terminal and see if it comes on if it does your remote wire coming from the headunit is bad or cut
Posted on May 19, 2009
  • 524 Answers
SOURCE: ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Posted on Mar 22, 2010
  • 7 Answers
SOURCE: I have a kenwood KAC9102D
speed hacker
Posted on Jan 14, 2011
Landcrusier 79 series 2006 model. keep blowing the tail light fuse after i hooked up a stereo. any ideas?
Locate the LIGHT + lead on your radio.
Do you best on finding the factory LIGHT + lead.
Use this old lead to trigger night lamination on your new radio.
If you can not find this lead then look for closest interior night lamination and tap into that positive lead.
Mar 01, 2013 | Toyota Vehicle Parts & Accessories
Ive just installed two 12in kicker cvr's and i bought the kenwood kac 7205, and ive hooked up everything right and used a digital multimeter to check that the current is coming throught but the amp...
So you check the remote wire to make sure there is 0.5amps running through it, right? Check the fuses of the amp? Checked your ground? Hope this helps
Aug 22, 2011 | Car Audio & Video
Ive got a 5channel zeus z7oo & im hooking up
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
I just installed a kenwood dnx7140. Everything is
Have you checked to see if the sub amp is turning on. Check to make sure you have at least 12 volts on your power as well as your remote turn on (Blue/White on radio harness).
If everything is hooked up correctly, it is possible that the preout is turned off. Some headunits have selectable preouts. If so you should be able to turn the sub on and off in the menu.
Hope this helps
VOTE
Mar 08, 2010 | Kenwood DNX7140 Car GPS Receiver
Subs and amp problems
make sure you have the wires from the amp to the box, and the box to the subs hooked up right... red is positive black is negative
Dec 28, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Gas in oil!!
check the fuel pressure regulator, the diaphrams rupture causing fuel to be sucked into engine / you could have an head gasket that needs to be replaced. do a compression test on all cylinders i think you will find atleast 1 cylinder real low.
Nov 16, 2008 | 1987 Subaru Gl 4WD
My buick is acting up help!!
check all fluid levels, replace battery with new one
Jul 07, 2008 | 1994 Buick LeSabre
Dec 22, 2007 | Pioneer GM-7200M Car Audio Amplifier
HELP please!
ok on the factory radio there is an adapter kit you can get that plugs into the back of the headunit and will push the sound to the subs i had one in my car till i got a new headunit and it worked fine. id recommend that you go to your local sound shop like a detail shop or some place that installs them for a fee and ask them what you think
Nov 05, 2006 | AudioBahn A2300HCT Car Audio Amplifier
Car Audio & Video Logo
Top DHD Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Tygh Duval
Tygh Duval
Are you a DHD Car Audio and Video Expert? Answer questions, earn points and help others
