Question about GE Microwave Ovens
Ge micowave je2160sf0
Mic does not come on but timer and all displays do when you push start it try's to come on but stops and timer keeps running
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Profile micowave model JE2160SF001 won't cook
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden elsewhere, which is very helpful when troubleshooting, testing, and locating components.
If you only need a switch, you can order a universal type
here for $5 postpaid.
Posted on Jul 25, 2009
vetteman3002
  • 2299 Answers
SOURCE: GE Profile Microwave jvm1870sk04 -
The control pad is bad. What does it do when the timer counts down? Does it stop running then?
Posted on Sep 19, 2010
davidbroo637
  • 7 Answers
SOURCE: PANASONIC MICROWAVE MODEL NN524M
I have had many of these ovens and found it to be the Magnetron never try to fix a microwave yourself.
Posted on Oct 20, 2012
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
Micowave just stopped working
The main fuse in the microwave oven has blown, this is often caused by one or two door switches going bad usually the result of food partical build up and must be replaced to fix the problem.
Mar 18, 2012 | Sunbeam Microwave Ovens
Microwave beeps
HI. the touch pad is defective at this point. you will need to replace this damaged touch pad board asap. this will fix your issue.
Aug 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Jul 23, 2009 | GE Microwave Ovens
The micowave will not heat or cook anything
PLEASE HELP ME TO FIX THS PROBLEM....
Mar 10, 2009 | GE Microwave Ovens
Jul 15, 2008 | Panasonic Microwave Ovens
Sharp model number: R-320HQ (1200 watts)
the electronic circuit are corroded timer does not function / the IC program was lost of memory such as function / if you have some old look a like Sharp Model you may transfer control panel.
Jan 05, 2008 | Sharp R-510HW Microwave Oven
Micrwave starts but then quits
Microwaves should only be worked on by fully qualified repair people and my advice to you would be to bring it to such a person,they can be dangerous to work on due to the presence of such high voltage, other than changing a light bulb any other repairs are out of limit.
Jul 19, 2007 | GE JVM1441 Microwave Oven
Microwave Ovens Logo
18 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
