Question about ASUS KB73211 Wired USB Keyboard OEM
Does this model have a backlight? If so, how do you turn it on???
How do i turn on keyboard backlight on lenovo flex 2-15
Fn + Space (on select
models): Turn on/off the keyboard backlight
Aug 27, 2014 | Lenovo ThinkPad Computers & Internet
T8500 Backlight
Here is a link to the user guide: http://www.giantintl.com/ContentManage-new/manuals/Moto/T8500%20English%20only%20June5.pdf
I did not find anything mentioned about the backlight function. However, on other TalkAbout models the backlight will automatically illuminate when you press any of the buttons other than the PTT and the musical note, and then the light will remain on for 5 seconds before automatically turning off. I do not know if this is the same on the T8500.
Best regards.
Feb 22, 2013 | Motorola T8500 Two Way Radio
Laptop backlight won't come on
Hi Fletcher,
Nowadays laptops come with an option to turn off the backlight to save power.
Since you have not included the model no of your laptop, i can't give specific info on how to turn on the backlight.
You can check the user guide of the laptop.
If that is not the case, the backlight board might have gone out and needs to replace it.
If you don't know how to do that, i would suggest you to contact a technician.
Sep 30, 2011 | Compaq Presario Notebook
I replaced the lcd screen. Now when the my camera is turned on i have a black screen with nothing on the lcd. Not even a menu display. I have pushed the lcd ribbon as suggested but no luck. Need advise....
The backlight is not turning on, it's the smaller of the two ribbon cables on the LCD assembly.
Make sure you have a backlight on your new LCD (not everybody sells it with the backlight!) or reuse your old backlight with the new LCD.
Check the backlight cable, is it ripped? Even slightly? If so, you need a new backlight.
Thomas Drayton
Owner Darntoothysam.com
Affordable Digital Camera Repair
Aug 03, 2011 | Canon PowerShot SD870 IS Digital Camera
I changed the batterys in my 1F78-151 thermostat and now the backlite does not work.....
• Display Backlight - (Not available on earlier models.) The display backlight improves display contrast in low lighting conditions. Selecting backlight ON will turn the light on for a short period of time after any button is pressed. Selecting backlight OFF (default) will keep the light off. Turn the display backlight feature ON as follows: 1. Press TIME and RUN buttons at the same time. The display will show "d-L" and "OFF" alternately
Dec 22, 2010 | Heating & Cooling
Does the Asus U50F have a keyboard backlight? & how to turn on?
No i'm sorry but that model has no keyboard backlight. If you wanted one which did have a backlight you would have to purchase a customised one.
Regards.
Apr 12, 2010 | ASUS Computers & Internet
My acer extenza 4420 backlight wont turn on
most likely:
1. backlight is dead (search for replacement displays).
2. backlight power-inverter is dead (check ebay for your model +inverter to see if there is even one in your model)
3. (very unlikely) wires which power the backlight may be worn from bending over time.
for the time-being, connect an external monitor, if possible, so you can access your system. connect it, power-on, and it should work by default -if not, hold the Fn key and press F8 (usually this key) to enable external display output.
and.. good luck!
Aug 31, 2009 | Acer Extensa 710TE Notebook
Backlight
hi
ther is only 1 option for this unit
http://www.uniden.com/pdf/BC72XLTom.pdf
page 50
-Using the Display Backlight-
To turn on the display light for easy viewing at night, press . The display lights for 15 seconds. To turn off the light sooner, press again.
other models have more options but this one doesnt
same for the 92xlt
D
Oct 10, 2007 | Uniden BC72XLT Handheld Scanner
How do i get the backlight on and off
Follow this link for the manual http://support.radioshack.com/support_electronics/doc61/61170.pdf That model does not have the ability to turn backlight on or off, your display may be on it's way out. Try resetting it first though, refer to page 66 of manual. Good Luck
Aug 11, 2007 | Radio Shack Pro-2052 Scanner
ASUS KB73211 Wired USB Keyboard OEM Logo
127 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
