Question about Lexmark Z600 InkJet Printer
My Lexmark Z600 has stopped using the colour 27 cartridge. On test print it only shows black test lines and on a colour picture it prints black. When printing it shows the colour cartridge as full. I have tried a new colour cartridge but it is still the same.
  • 50 Answers
Apparently the default printing color has been changed, you have to change it back either from "control panel/ printers /right click on your printer and click properties, and choose color for printing." or you can do it per printing job, when it shows u the printing options, (like number of copies and other (basically same window from the control panel). if you do it from the control panel whatever you choose, that would be the default, otherwise it is per job change and is not permanent.
Posted on Jun 18, 2009
My printer does not acknowledge presence of ink cartridges.will only print in black
It could be that the color cartridge is not seated properly or just needs cleaning.
Try to re-seat your color ink cartridge. Open the printer cover > remove the color cartridge > re-insert the color cartridge and make sure it's properly seated > close the printer cover. Try to print again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print cartridge nozzle. Please follow the steps below to fix print quality issues with your model:
  1. On your computer, go to Start menu.
  2. Go to Programs.
  3. Go to Lexmark Z600 Series folder.
  4. Select Lexmark Solution Center / All-In-One Center.
From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through to clean the print cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
Feb 04, 2012 | Lexmark Z600 InkJet Printer
I install new inkjet cartridge for my Lexmark Z600 printer, but the printer still showing no ink
Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
If problem continues and you're using brand new genuine Lexmark cartridges, please contact Lexmark Technical Support Center for further assistance.
Jan 07, 2012 | Lexmark Z600 InkJet Printer
I am trying to print and nothing comes out on paper. cartridge black half full and color full and it will not print anything from an open document to a new document with some typing on it. lexmark z600...
Try to clean the print cartridge nozzles. On your computer, go to Start menu > All Programs / Programs > Lexmark Z600 Series > select Lexmark Solution Center. From the Maintenance tab, select Clean to fix horizontal streaks. Your printer will then print a clean test page forcing ink through the cartridge nozzles and clean them. Try to print your document again and to check if print quality is achieved.
Jul 25, 2011 | Lexmark Z600 InkJet Printer
I have a Lexmark 1200 printer. Colour promlems
It could be that the cartridge has become dry.
you have to try several head cleans using the printer software and if that doesnt help then the cartridge needs to be replaced.
Nov 03, 2009 | Lexmark Optra Color 1200 Led Printer
Black ink not printing
may be the black colour is frozen
Jul 14, 2009 | Lexmark Z600 InkJet Printer
My colour cartridge ran out on my Z2390 and I replaced just the black cartridge now it wont print as it says I need to replace the color one
Lexmark used remote access to sort the problem. Although I altered the setting on the print page to black and white it was defaulting back to the original settings. They changed this through my computer and the print settings ans now all is ok.
Jun 18, 2009 | Lexmark Z600 InkJet Printer
Not find cartridge?
Try to clean the carrier tab circuit of the printer and tab circuit of the cartridge maybe it suffered loss connection between the printer and the cartridge...
and you mention that your 27 cartridge is already old..you should wipe it on the wet cloth ..in order to have a good print outs..
May 12, 2009 | Lexmark Z600 InkJet Printer
My printer now only prints blank pages.
try wiping the contacts (gold colored spots) with a tissue, and after wipe the ink despensing end.
Dec 03, 2008 | Lexmark Z600 InkJet Printer
Lexmark Z600 ONLY print test pages
Seemes very daft, and sounds like a twit, but not really.
When I recieved the new cartridge I placed it in the correct cartridge retainer in the printer matching up the dark green colour of the cartridge and the top clip, and it printed nothing even after a tryed re-seating it.
So I placed it in the other thinking maybe I somehow might have placed it in the wrong slot, so I placed it in the other (Colour), and set that up as I did the other, and it printed a blurred page but then stopped printing.
After that I then placed it back in the other cartridge retainer, set it up as the previous times when it did not work, and then it worked.
Seems strange and simple, but it did not work the first time at all, and after faffing with it finally did.
This might help someone, and then again might not.
Oct 07, 2008 | Lexmark Z515M InkJet Printer
Lexmark 3200 colour printer
Dear friend There may be serious problem in the printers mother board which is not sending any signals for the bklack cartridge and should be diagnosed. Pran
Jan 21, 2007 | Lexmark Color JetPrinter 3200 InkJet
Lexmark Z600 InkJet Printer Logo
143 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
