Question about OKI C5500n Laser Printer
Oki c530dn firmware - OKI C5500n Laser Printer
Firmware update of 2012 OKI MC562DN.
Then sorry but that is what you need to do. OR buy anew printer.
Jun 23, 2017 | OKI Office Equipment & Supplies
Msg says Drum Unit Life Order K Toner but my K Toner is at 90%.
The drum may have an electronic counter installed and after so many pages being printed, even though it is still good, it will determine that it is time to replace. You may be able to replace the electronic counter. If not, you will need to replace the drum.
Jul 03, 2014 | Oki Brand Oki C530dn Laser Printer Duplex...
How to fix the Oki Toner Waste Bin Full Error
Some OKI's have the sensors in the side frames, using a q-tip clean off they are round units, about the size of a nickel.
May 05, 2014 | Oki Brand Oki C530dn Laser Printer Duplex...
C530DN 142 error
Image drum up-down movement position detection error. Is the image drum unit removed and installed smoothly? If yes then re-install it If no then Be sure of the connection of the image drum
up-down clutch connector.
- ALSO -
Is the connector of the image drum up-down clutch is connected properly? If yes then Replace the toner sensor board. If no then Connect the image drum updown clutch properly.
Mar 04, 2014 | Oki Electric Industry C530DN Led Printer
Error code 980
Media has wrapped around the fuser. After letting it cool you can try to unwind the media but you may need to replace the fuser
Dec 30, 2013 | Oki Electric Industry C530DN Led Printer
Waste toner full
Replace the corresponding toner cartridge
Nov 19, 2013 | Oki Electric Industry C530DN Led Printer
Firmware update
Unfortunately, Oki does not make their firmware available on the web -- except to Oki authorized dealer/service centers. You will have to either pay for it (I would not), or find a dealer who will do it for you. Of course, you could always sell it on ebay, and buy an hp. All of their firmware updates are free and open to anyone. They even come with instructions on how to do it!
Apr 25, 2010 | OKI C5510 MFP All-In-One Led Printer
Oki C5500 dont have TC/IP menu, do you help me.
Symptom:
Unable to reach Printer from local network or Printer falling off network and needs to be rebooted before being able to print
Cause:
ecblank.gif ecblank.gif ecblank.gif Resolution:
Install OkiLAN8300e Firmware 4.06 (C5500/C5800) or 4.55 (C6100) update using Oki LPR Utility
Are you on a Mac?
Mar 10, 2010 | OKI C5500n Laser Printer
900.00 Service
When I have seen this error in the field, I have cured it by updating the firmware. Lexmark has a paper in their Knowledge Base on 900 errors:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:556:0:0&framed=&docid=ENUS22164&relevance=1
Go through the suggested steps to try to narrow the problem down.
But if it needs a firmware update:
http://support.lexmark.com/printerfirmware/
Use code: Isfap129 to download the package the C530dn.
Hope this helps!
Nov 29, 2007 | Lexmark C530dn Laser Printer
OKI C5500n Laser Printer Logo
128 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
