Question about kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower Engine Motor ()
Hp kawasaki has vibration noise after only 4.5 hrs of use
I just purchased a ******* SD 60 mower with a 24 hp Kawasaki engine. We purchased Friday and after only 4.5 hrs of use the engine is making a vibration noise
wayneman01
  • 301 Answers
SOURCE: Kawasaki Mule 500 KAF 300 starter will not work below 60 degrees.
Using a lighter viscosity engine oil can make all the difference. Try something on the order of a 5W-30 for ambient temperatures of 60F or below. Of course, it could also be that your starter solenoid is in the early stages of failure. You can easily check it by using a large screwdriver to bridge the two large cable connections on the top of the solenoid. If the starter spins when you do this, then the solenoid is bad.
Posted on Dec 07, 2009
  • 3 Answers
SOURCE: 1999 kawasaki Drifter Vibration
I have owned my 1500 since new, the vibration around 50mph I would say is normal for this motor..I think it is just the resonance of the engine at this RPM...On my own bike I replaced the U joint( which wasn't defective) wheel balance and brg problems eliminated,etc. As for the remaining vibration by pulling in the clutch and the vibs go away.Gagets stated in an
e-mail it could be rubber harmonic balancers in the engine that got brittle may be the problem..Also I think worn motor mounts may contribute to the problem. My only concern is getting stuck somewhere...My drivetrain is ok so I'll live with a little vibration until I have to take the engine apart for some reason.
Posted on Feb 15, 2010
Testimonial: "Thanks alot! Also is yours the 99'?...I heard they have a defective clutch (mines slipping) I wonder if that may be a contributing factor???"
RonInFla
  • 86 Answers
SOURCE: I have a kawasaki 21 hp on a 2008 toro O turn
Find a different dealer...The problem doesn't have a "101" type of solution. Being able to fix the problem requires knowing what you're looking at and recognizing what's out of adjustment. There isn't a "base line" to start at. A few shop tools are needed. Especially a tachometer. A rack type assembly under the carburetor, where the cables attach, can be moved as a whole unit to adjust how the springs effect the governor, which in turn, changes how the governor controls the carburetor. Yours is set too low, with too much tension, and the springs are too tight.
Find a better dealer...
Posted on May 19, 2010
  • 146 Answers
SOURCE: Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Posted on Jun 04, 2010
  • 10865 Answers
SOURCE: have 24 hp kaw. engine on Cub lawn mower. At idle,
Hello. The usual cause of carb "hunting", is a weak governer spring. Although it might look fine it may not be and I would replace it. Another possible cause is a float problem. Finally it could also be the fuel filter or a chunk of debris in the carburator.
Posted on Jun 08, 2010
I purchased a Kawasaki (dfi) 31 hp engine. I fitted a hydraulic pump to engine, and when attempting to start (wired according to diagram), I got no spark and got no fuel.
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Best Manuals
Sep 07, 2017 | HP Garden
Gravley zero turn kawasaki 24 hp engine wont start
It seems to be getting spark, check is it or isn't it?
Jun 20, 2017 | Cars & Trucks
Blown Kawasaki engine on a Husqvarna YT48XLS lawn tractor -- only 50 hours?
return it and demand your money back and go to better business bureau
Jun 04, 2015 | Husqvarna Garden
23 hp fh680v motor wont start carb keeps filling up with fuel but plugs are dry
perform a compression test low compression will not draw in fuel into the cylinder see them blow head gaskets around 2500 hrs
Sep 24, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Have 24 hp kaw. engine on Cub lawn mower. At idle, engine is erratic, revs, then slows, revs, then slows.
Jun 08, 2010 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower Engine Motor () Logo
Top kawasaki Garden Experts
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
dannydoesita
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
