Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Set time brighter display
Display light for time,cooking is very dim,how can I make it brighter?
Try plugging the cord into another outlet and see if it gets brighter Dawn.
Aug 08, 2017 | Cars & Trucks
How do you make the number that tell time light up darker so you can read it.
If you want to make the display brighter (remember, it auto dims in low light):
1. Hold down the "clock set" button while pressing the "volume" button up or down (up for brighter, down for dimmer).
Jun 10, 2014 | Bose Wave Radio
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
Uneven backlight
Your set is probable defective
Sep 21, 2017 | Sansui Televison & Video
Brighter display on the left side of monitor than the other side
Sounds like the lcd screen might be going bad. There are no display settings that can modify parts of the screen. It's all or nothing as far as settings go. Have you tried hooking up an external monitor to see if it displays correctly? If it shows correctly on an external monitor the problem is definitely with the lcd screen. If they both show the same image of brightness on the left side, then your video card in the laptop might be going bad.
Apr 18, 2012 | Computers & Internet
LED on my Sony ICFC218 is dim
i found that if I repeatedly press snooze/date/sleep off (big button) it will change the dim setting 3 levels... dunno how many times but I press it like 20-30 times and it works
Dec 02, 2011 | Sony ICFC218 Clock Radio
The time display is dark. the radio works and I can set an alarm but the time display is dark. I seem to remember there is a battery somewhere that may need to be replaced.
it may be that the display died or it not getting enough light on the screen because it has a senor that when the lights turns on it will be brighter or if this does not work call bose at 973 644 BOSE
Jul 10, 2011 | Bose Wave Radio
Ipod touch 1st generation display very dark
You probably reduced the brightness one time, but you just forgot about it. To make the display brighter, do this:
>on your iPod touch screen, go to Settings.
>once the Settings window is open, you'll see Brightness from the list, tap on it.
>now, you drag the button to make the display darker or brighter. drag it to the left to make it darker, to the right to make it brighter. You'll notice the display darkens / brightens simultaneously as you drag the button.
For more iPod touch / iPhone tips, click here. Feel free to comment on my tips if you have other questions.
Mar 05, 2010 | Apple iPod touch
Screen is very dark. how do i make it brighter
You can adjust the power options (power save/ economy mode) settings and also the display settings in your control panel.
May 12, 2009 | Acer Aspire 5630 Notebook
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
12 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
