Question about Electrolux Dryers
Dryer overheating while drying it makes an odd sound
2 Suggested Answers
mc1bean
  • 3053 Answers
SOURCE: Dryer is making an odd rolling sound and takes
Hello, link
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about Dryers and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-dryer1.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks, Mike
Posted on Oct 30, 2011
I push the button to dry my clothes and it is still damp. The dial has a 30 minute side on each side. It is a new machine. I'm used to setting the dial one time and my clothes are dry.
Make sure you don't have the vent kinked or stopped up with lint. Sounds like your dryer may be overheating. The vent connects to the back of the dryer and pipes to the outdoors.
Apr 13, 2011 | Dryers
Dryer drum loose not lining up properly making a huge thumping sound
Identification of Dryer Problems
Signs that an electric dryer may need some repairs include the dryer not heating, clothing not drying fast enough, overheating of the dryer, the door not locking shut and the dryer not starting at all. Any of these are signs of an underlying problem that can usually be solved without the help of a repairman.
Effects of Dryer Issues
If an electric dryer doesn't heat properly, it prevents the clothing from becoming dry in most cases. Restricted venting can cause clothing not to dry fast enough, as the dryer will cycle the heating. Overheating dryers can ruin clothing or cause burns. If the door on a dryer wont close, it is impossible to get any laundry dried. A dryer not running at all can be very frustrating and lead to owners needing to use a laundromat.
Considerations for Solving Common Problems.If the dryer wont heat up, owners should check the circuit breaker to see if it's down. The voltmeter at the wall plug should read 240 volts. Checking the power cord can show owners if the wires are burned where they meet the dryer.Clothing not drying fast enough and overheating are signs of restricted venting. Removing the vent hose from the dryer can help owners decide if this is the cause of clothing not drying. If the hose is removed and the dryer runs normally, the vent should be cleaned.White plastic or thin foil ducts can also lead to overheating. Only metal ducts should be used with dryers. Kinks in the vent hose can also lead to heating issues. Overheating can also be caused by a shorted heater coil, a bad operating thermostat or worn drum seals.If the door on an electric dryer will not close, it is usually a problem with the door catch. This can be solved easily by purchasing a replacement door catch for the dryer.
When a dryer wont run, it could be a number of issues. The circuit breaker may be down or the wires at the plug may be burned. It may be an issue with the door switch. The door switch should click when closed. The thermal fuse should be checked for any issues.
Preventing Dryer Problems
The electric heating element, thermostats, fuses and thermal cut-off should be checked regularly for continuity. Dryer vents should not exceed 18 feet without a helper blower in the duct. Vents that are run vertically need to be cleaned out once a year. A meter can be purchased and used to diagnose problems with your electric dryer.
Warnings and Tips.Inexperienced people should never try to fix electrical problems at home. A professional should always be used if dryer owners suspect a more serious problem. Dryer owners can purchase kits to make cleaning dryer vents easier.
Mar 11, 2011 | Whirlpool Dryers
Our Bosch Ventless AXXIS Dryer system is overheating causing the sensor to sound. It is not drying properly either. Can you troubleshoot??
Overheating is most probably caused by low air flow past the heating element. High air flow would not allow the air to overheat. Check to be sure the fan is rotatingn freely and then check the heating element/wires for dirt or other obstructions. We were having "burning" problems that were revealed to be an errant latex glove that excaped from my wife's pants pocket during an earlier drying cycle. When it hit the elements, it began to cause a scortching smell and partially melted. In this instance, the air flow about the element was restricted and the reamining air overheated and the sensor sounded. When the sensor sounds, heating ceases and you will get non-uniform drying. I picked off the pieces of the glove from the wires and except for an unrelated drive belt breaking, we have not had problems.
Jan 22, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Dryer wont start dryer started smoking last used now wont start has power. door switch checks fine. has power to start switch
That sounds to me like an air restriction has caused overheating.
The blower wheel on these dryers tends to start slipping with age. 528f0fa.jpgThe slipping makes the dryer over heat and cause the safety's to shut down quickly.1b3c53e.jpg 32276fa.jpgThis takes a lot longer for the clothes to dry. aff5565.jpgFinally the limit opens and kills the whole thing. To service it 9d5ebcf.jpg61b049c.jpg
Was this helpful?
Sep 13, 2010 | Maytag Dryers
I have a GE Dryer Profile Harmony. It is several years old. The dryer is not blowing air out the back ventilation so not drying. It is making a quiet odd sound as well. When I troubleshooted I shut the...
You vent is plugged very bad. Disconnect the vent tubing and thoroughly clean it out. It will heat and dry like new afterwards guaranteed. These dryers have sensors that shut the burner off if the exhaust is not venting properly. Once its cleared out it will run perfectly again
Apr 09, 2010 | GE Profile Harmony DPGT750EC Electric...
A STRANGE SMELL WHEN DRYING..
sounds like brushes they can cause a burning smell......as for clothes smell after drying the fan in the heater could be dirty but generally that would mean the heater will not work
Mar 18, 2009 | Hotpoint Aquarius WD63 Front Load...
GE Dryer makes deep sounds when hot and tumbling
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Dryer not drying completely
sounds like motor overheating if it makes a growling sound when trys to start and after shut off has to cool down a while before it will try to start ..motor
Sep 03, 2008 | Dryers
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
12 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
