Question about Marantz VP4001 DLP Projector
Projector won't power up - Marantz VP4001 DLP Projector
Blue power light frozen, projector won't turn on
Page 47 has nothing to do with this problem! Thanks for wasting minutes of my life
Nov 28, 2012 | ViewSonic PJD6211 Projector
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
My viewsonic 3d projector won't turn...but it has
You should replace the lamp it is already damage, when you replace the lamp do not forget to reset the lamp hour meter.
Aug 22, 2011 | ViewSonic Televison & Video
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
I went to replace the bulb and when I plug it back in there is no power, no power light or anything. DS303
this is a common problem with optoma projector, if you replace the lamp yourself, it won't start!! let's sue them
Jul 16, 2011 | Optoma DS303 DLP Projector
HP VP6210 won´t turn on at all
try to replace all the capacitors on the motherboard. This are the only parts that leak in time. Try otherwise to reset to counter or update the firmware on your machine on the infocus site.
Goodluck !
Sep 04, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
PJ-TX100 Projector won´t start up out of Stand-By
Hi Mario
If there is no response on the Projector it normally means that the Mainboard is faulty.
Check if your machine is still under warranty because this quite expensive to replace.
As far as the schematics are concerned - I'm unfortunately not able to help you out with that.
Apr 02, 2008 | Hitachi PJTX100 Multimedia Projector
Marantz VP4001 DLP Projector Logo
26 people viewed this question
Top Marantz Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
Are you a Marantz Office Equipment and Supply Expert? Answer questions, earn points and help others
