Question about Boating
Looking for a starter solenoid wiring diagram
I have a 1988 Johnson outboard motor 20HP (used) and need to replace the starter solenoid, which was missing. I have a solenoid to install, but do not have a wiring diagram.
Motor Model Number: R20CRCCA
Appreciate any help
  • Mumbles
    Mumbles Feb 03, 2016
    A marine solenoid is wired different internally than a car solenoid so be careful. In a outboard solenoid, current goes thru the two small terminals and then thru the safety switch before going to ground. A car solenoid puts full battery power out of the second small terminal and is grounded thru its frame. Both look the same but are different.
  • 77 Answers
Save yourself some money and go get a lawn mower solenoid and find a way to mount it yourself. I have done a johnson outboard and a tigershark jet ski this way with no problems.
Posted on Jun 21, 2009
  • bwwatson Jun 21, 2009
    you should have a 3 post solenoid, one post will be a hot from the battery, the other post will hook to your ignition switch, the third will run to the starter itself. one post has 12 volts running to it all the time, the second gets 12 volts sent to it only when you turn key to start position, that closes a plundger inside the solenoid which closes the circuit and send the 12 volts from the battery to the starter, then when you release the key the plunger comes back up and opens the circuit. If you tak a good look at it i know you can figure it out without a diagram. Good Luck.
And older Johnson 115HP outboard will click only once when the key is turned to start
pull the starter and have it bench inspected by an accredited auto electrician
there could be an armature problem with corroded commutator bars or brushes stuck off the commutator
Jul 19, 2016 | Boating
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What year and model is my antique evinrude motor?
I have never seen anyone answer these questions.if you looking for a condenser they are all the same.eg a 1965 40hp condenser will fit a 1955 20hp
Oct 01, 2014 | Sierra International 18-5199 Marine...
Wiring schematic manual
Check here,
http://www.kicksup.com/evinrude/
Aug 15, 2014 | Johnson Evinrude Starter-Outboard 97 V4-V6...
My 1977 85 hp Johnson motor will trim up but not down. I traced the wires from the trim switch to the solenoid and all are hot. I replaced the solenoid but it still will not work. I can cross out t
2 solinoides , one for up and one for down !!!! test trim switch then try swopping up solinoide to the down and problem could be solved !? check wires !
Jul 31, 2014 | Sierra Outboard Starter for...
50hp johnson outboard
Look on thin red wire that leads from starter solenoid,holder is normally situated on top of cylinder head
Dec 15, 2013 | Boating
Starter motor on 130hp Johnson outboard won't
does it turn or can you hear a click as you try ? if its not turning check the starter brushes and if it clicks then replace solinoide !
Apr 04, 2012 | Yamaha Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Boating Logo
2,929 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
