Question about Home
Kohler Mastershower Tower body sprays don't work
The body sprays just stopped working on our Kohler K-74 Mastershower Tower. The water flows from shower head and water fall, but nothing comes out of the body spray heads. I have the manuals, and I see there's a pulse generator, which could be shorted out or something, but is that even involved if we're not looking for the pulsing mode?
5 Suggested Answers
jonbrown725
  • 73 Answers
SOURCE: Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Posted on Jan 17, 2009
snap101
  • 117 Answers
SOURCE: shower body three way diverter problem, no water to one port
try taking the shower head off and see if there is something stuck in it. sometimes things will come through the water lines and lodge themselves in the valves as well. if the shower head isn't clogged try dismantling the valve that turns the shower head on and then turn the water on when its out and flush the port out.
Posted on Aug 01, 2009
bloues
  • 56 Answers
SOURCE: Delta Victorian 5-Spray Hand Shower has no
hello
of corse ... sir want to get thread tape befor trying to fix the head .
unscrew the head of the shower not the arm.
after unscrewing the head ,look at the back were the thred is, there will be a siff. thust clean out the sif, put thread tape on the head again and bobs your uncel hehe. if that dosent fix it let me know .
Posted on Jul 08, 2010
  • 3 Answers
SOURCE: I need troubleshooting help with my three function transfer shower valve .
valve is bleeding by remove and check the condition of cartrige look for wear or dirt
Posted on May 02, 2012
This shower has 3 body spray jets. The lower jet does not work. I need to remove the lower one to see if there is debris in the line, blocking it. It is a Kohler k 8002 cp body jet. How do I disassemble it...
There are some clips on the top of the spray head that fasten it into place. I found this pic that may help and your Kohler owner's manual should also have more info.
Mar 19, 2015 | Kohler Electrical Supplies
How to replace soap dish on kohler mastershower slidebar. can't seem to take it apart.
Dear Sirs,
You have to deassamble the part then you can take of the shop dish
Oct 10, 2013 | KOHLER MasterShower Three-Way Brushed...
Low water pressure
pull heads and make sure no trash in system....
Jan 24, 2012 | Kohler Home
The "turning" part of the head has almost become
yes you just have to be careful to align back up and tighten all parts...
Feb 15, 2011 | Kohler K-8506-CP Polished Chrome...
I have a single handle kohler bath tub faucet I am not getting any cold water out. i have taken this apart and found nothing that i can see that would impede the flow of water ?is the mixer valve at the...
If the faucet was working before and then just stopped, it is the mixing valve or a clogged supply line.
turn the water off and remove the mixing valve. Turn the water on and see if you have good flow from both hot and cold ports inside the faucet.
Caution- this procedure can get messy, close the shower curtain or door.
Call Kohler and ask for a new mixing valve for free.
Sep 12, 2010 | Kohler Plumbing
Leaking
Make sure you fitted the rubber O ring on the end of the shower flexible hose. That will seal the water pipe.
Mar 29, 2017 | Kohler K-9511-BN MasterShower Shower Arm &...
Low flow from Kohler K15160 spray kitchen sink faucet. If I take off the spray handle I can fill a jug through the hose alone (including the filter screen) in 15 seconds while with handle on the same...
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
Mar 01, 2009 | Kohler Coralais Black Single-Control...
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
