Question about DBPOWER PTZ Wireless IP WaterProof Outdoor IP Camera 3X Optical Zoom IR-Cut
Unable to start video
I have a DBPower PTZ wireless IP Outdoor Dome camera, I have set it up, firstly it does not work on Wireless so I have wired with an ethernet cable, I have 2 other bullet cameras which I have set up fine and can view and record, but when i try and set up the dome camera in the software provided IPCMonitor, I can not get a picture, the message I get when I try to start is "Video failed to start", I have checked all the settings and everything is set properly, but I just can not get a picture. If I use the Search tool provided it comes up on the search and if I double click like the instructions say then the picture comes up fine in FF and in Mobile mode, but will not give me a picture in IE mode... I am pulling my hair out on this one as i would like all 3 camera showing on 1 program. I have installed the OCX application as per instructions. The camera is a B series, originally allocated the IP code as 192.168.1.99 port 99, but I had to change that as my router is 192.168.0.6 so it had to be changed to ab
How can I ffind a set up for air sight xx42a camera
I hope these instruction pages upload large enough to be seen without a problem. If not I will try again.
Jun 10, 2014 | X10 AirSight Wireless / Wired Outdoor IP...
Why won't my camera respond to move commands?
hi,
what do you use to command? hardware or software?
if you use the remote control, is it on same channel than the receptor (camera)? (see letter and number !) same for hardware IP controler, see channel, and if software, are you signed in as admin or only viewer ?
May 13, 2014 | X10 AirSight Wireless / Wired Outdoor IP...
Not recognized
Try turning it off and on waiting a bit between cycle while it is connected to computer. Also hopefully you installed the software for it.
Apr 14, 2014 | X10 AirSight Wireless / Wired Outdoor IP...
Va033k ipcamera does not work
Check the power adapter for continuity. If you experienced a power outage or surge lately, the adapter and/or camera may be damaged. Try to use camera with alternative adapters of the same voltage/current/.
Feb 09, 2014 | DBPOWER 2x Wireless Dbpower Va033k Ip...
WVC210 CISCO PTZ camera... i can access through ethernet but can't access through wireless. I had tried installing in the sameway specified in the manual.
I had the same problem. Here was my successful solution:
reset the modem
only change the SSID (do not activate the security yet)
reset the camera
install the camera
set the static ip address
set the SSID to match the modem and save settings
unplug the power and the ethernet to the camera
plug in the power to the camera and wait for the lights on the front are illuminated
go back into the camera and set the security settings
go into the modem and set the security settings.
I hope this works.
Jul 07, 2011 | Cisco WVC210 Network Camera
Wireless installation for DCS-5220
Plug in the network cable first and make sure the following settings are correct:
1. SSID is the same and set to broadcast
2. You are using the same WPA AES password as the router (or WEP password if you are using WEP)
3. The wireless antennae is connected
4. The camera is located not to far from the router
After that, remove the network cable and restart your camera.
May 19, 2008 | D-Link DCS-5220 Network Camera
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
DBPOWER PTZ Wireless IP WaterProof Outdoor IP Camera 3X Optical Zoom IR-Cut Logo
79 people viewed this question
Top DBPOWER Cameras Experts
Are you a DBPOWER Camera Expert? Answer questions, earn points and help others
