Question about Coleman CPX 6 Ultra High Power LED Spotlight
My spotlight only works if plugged into charger
Hi my Coleman cpx 6 compatible will only work when the rechargeable battery is plugged in. Even the battery pack where you insert the batteries doesn't make it work
3 Suggested Answers
al_kupchella
  • 843 Answers
SOURCE: In the Coleman 5312 Retro Series Lamp is it
Brentonb, In the event that you don't get a direct answer (which is likely, since this is a pretty obscure question) I suggest you troubleshoot it this way. Remove the bad battery. Use the charging device that came with the lantern and wire it temporarily to the device in place of the battery. This will supply the correct voltage, but takes the possibly shorted battery out of the circuit. If you are certain you have the polarity correct and you know that the charger works, then you have your answer. good luck.
Posted on Dec 03, 2010
joeguest2
  • 2080 Answers
SOURCE: does the coleman charger 1 spotlight model #
Yes it does.
See the product details at the following links:
http://www.amazon.co.uk/Coleman-Charger-One-Chargeable-Sportlight/dp/B0002JSZVU
http://www.coleman.com/coleman/parts/ProductImage2.asp?product_id=5347A718
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated.
Good luck.
Posted on Apr 15, 2011
Why doesn't lantern turn on when not plugged in?
I have a rechargeable spotlight and the directions specifically say not to turn it on while connected to the charger.
Mar 10, 2016 | Coleman Cpx 6 Rechargeable Power Cartridge...
How do i remove battery in coleman tent light
Coleman Customer Service can help you find the correct manual, or even just tell you how to open your light - if it is openable. NOTE: Some rechargeables do not allow the battery pack to be removed, so once it dies the unit is done for.
May 10, 2015 | Coleman CPX 4.5 Rechargeable Power...
Coleman 530 Lumens Spotlight needs a need battery FIFUTEC FP 1228, 12V 2.8Ah. Where can I find the right size?
Hi Mary, go to batteryspec.com. In the search box put in TR2.6-12 even though it's 2.6, it equates to 2.8 for our spotlights. The battery is around $20 with a 1 year warranty, and has the same specs (dimensions, terminal position) as ours.
Mar 05, 2014 | Coleman LED Rechargeable Spotlight
Battery and charger
You can get aftermarket 18V rechargeable batteries that may interchange with your Coleman battery and may even use the same 18V charger
May 11, 2013 | Coleman Cable Coleman 18 Volt Combo Drill...
WHAT IS THE VOLTAGE OF MY VECTOR MODEL VEC117FS
6 volts rechargeable battery. Check with the manufacture for a recharger for the 110v and or a car charger for your light.
Mar 27, 2012 | Vector 1 Million Rechargeable Spotlight
Spotlight will not charge
It seems like the charging circuit inside the light may be bad, contact Coleman to have the light repaired.
Jun 15, 2010 | Boating
Spot light is unable to recharge with the wall
While it could be the battery, it could also be the internal charger in the spotlight. When you plug it in, it bypasses the charger and uses the connected power. However, it is likely just a bad battery. The batteries only last 3 years in an ideal setting and since these lights are typically only used certain times of the year, the batteries discharge and go bad. New batteries can be found at: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Jul 18, 2009 | Vector 3 Million Candlepower Rechargeable...
Coleman CPX 6 Ultra High Power LED Spotlight Logo
90 people viewed this question
Top Coleman Camping, Backpacking & Hiking Experts
Jim London
Jim London
weirdtop
Are you a Coleman Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
