Question about Emerson GF827 DVD Karaoke Player
How to play my phone through karaoke machine
Where do I plug it in?
Can i hook up my ipod using a usb cord?
Won't play ITunes! This Karaoke is incompatible for Apple (ITUNES, IPOD, etc.) I even tried creating Thumb Drive (using USB) and then a CD. This brand Karaoke won't play the ITUNES songs.
:((( Very frustrated
May 22, 2013 | Memorex MKS8594GP Karaoke
My karaoke machine will not play CDs
the only suggestion I can offer is clean the laser lens with a Q-Tip and rubbing alcohol gently and allow several minutes to dry, if that fails! the whole assembly will need to be replaced.
Mar 15, 2012 | Venturer CD-2160 Shelf System
When i put a cd in to play, we cant get the words to show on digital screen??
You MUST use a special Karaoke CD disk to show lyrics on the screen. Plain music CD's will play music but NOT display the lyrics. Karaoke disks can be expensive... so shop online for Karaoke CD's. Some music stores, including Costco and other warehouses sell some Karaoke disks, but they are usually in a very small section of the displays.
Dec 27, 2010 | GPX Karaoke Party Machine
I just received a GPX JM250S Karaoke Party Machine. I have not tried a actual Karaoke CD yet. I plugged ipod in. Problem is- music is playing, then when I speak into mic music stops playing. There is no...
The music to sing along with apparently MUST come from a disk played on the unit. It appears that the external audio jacks are just to use the unit as either a boombox or to drive a larger sound system. You will have to convert your IPOD music into a Karaoke compatible CD to be able to sing along with it... They probably detect MIC input and mute any incoming signals from the RCA jack inputs,
Dec 26, 2010 | GPX Karaoke Party Machine
I have a fleco karaoke machine the problem is that when you put a cd in the machine the word error appears what do i do please help
Hello. These karaoke machines can be a pain in the neck in that not all karaoke CD's work in every machine. Check in your manual to see which CD's are recommended. I had the same problem until I went to the home page for my karaoke machine and found the exact CD's that would play. Good luck with it. J.
May 22, 2010 | Sony STR-DB930 Receiver
Karaoke machine wont play cds
I'm having the same problem with mine! As soon as I figure it out, I'll let you know...
Oct 20, 2008 | B&W 5.5" TV/CD+G Monitor Karaoke Machine...
MY KARAOKE MACHINE
I have the same type Caraoke machine that turns on but it does not play the CD....
Apr 30, 2008 | Audiologic DVCR-251
Blank karaoke machine
Try looking on the back of the machine for vertical and or horizontal hold controls (marked V-Hold and H-Hold) and try adjusting them, especially the horizontal hold.
If that doesn't help, then the next troubleshooting step would be if the machine has a video output you could try connecting to a TV/Monitor and see if the graphics appear there.
Feb 01, 2008 | B&W 5.5" TV/CD+G Monitor Karaoke Machine...
Emerson GF827 DVD Karaoke Player Logo
29 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
