Question about Automate AM6.2
Program an automate am6.2 - Automate AM6.2
What is the difference between Manual vs. Automated Testing?
Difference between Manual and Automation Testing is the pillar of Software testing, because whole testing is based on Manual and Automation Testing. In a project you can do either Manual or Automation Testing and you can also do both Manual and Automation Testing simultaneously.
Complete Difference between Manual and Automation Testing
Manual Testing Automation Testing 1. Manual Testing is a process which is done manually. 1. Automation Testing is a process which is done by the help of automated tools. 2. All the famous phases of STLC like test planning, test deployment, result analysis, test execution, bug tracking and reporting tools are obviously comes under the category of Manual Testing and done successfully by human efforts. 2. In Automation Testing all the popular phases of STLC are done by various open sources and purchased tools like Selenium, J meter, QTP, Load Runner, Win Runner and so on. 3. Manual Testing is a start of Testing, without this testing we can't start Automation Testing. 3. Automation Testing is a continuous part of Manual Testing. 4. In Manual Testing testers are allowed to do Random Testing to find the Bugs. 4. In Automation Testing we always test through Running Scripts. 5. In Manual Testing we find more bugs than automation by Error Guessing. 5. In Automation Testing we test the repetitive functionalities of the application. 6. It takes lot of time. 6. It takes less time. 7. Manual Testing would be run sequentially. 7. Automation Testing is done on different machines at same time. 8. Regression Testing process is tough in Manual Testing 8. Regression Testing process is easy in Automation Testing by Tools. 9. It is not expensive. 9. It is expensive. 10. More testers are required in Manual Testing because in this testing test cases need to be executed manually. 10. Few testers are required in Automation Testing because in this testing test cases need to be executed by using Automation Tools. 11. It gives low accuracy result. 12. It gives high accuracy result. 12. It is considered as low quality. 12. It is considered as high quality. 13. In this Testing we cannot do batch testing. 13. In this Testing we can do multiple types of batch testing. 14. It is considered as less reliable. 14. It is considered as more reliable. 15. No need of programming in Manual Testing. 15. Need of programming is must in Automation Testing. 16. It is done without interaction of any Tool. 16. It is always done using tools.
Aug 24, 2016 | Microsoft Video Game Consoles & Games
Pool turns on and off by itself.
What automation system is it? If you cleared the memorie & it still has a schedule running it may need a new control board unless u have a VS pump, these usually have there own built in automation system and might have a schedule programmed into it so if the main automation fails it will kick over to this & still run the pump. I need more info to properly diagnos
Nov 04, 2015 | Pool & Spa
Hayward h series Bo problem
make sure you have adequate gas pressure
May 17, 2014 | Hayward H-series Electronic Gas Pool...
My imac keeps freezing withen 3 hours.
You can do this with the built in program Automator. Hit record and Automator will follow your actions and turn them into a script. You can then set the script to run in the interval you requested. http://mac.tutsplus.com/tutorials/automation/10-awesome-uses-for-automator-explained/
Nov 10, 2013 | Computers & Internet
How to program a am 7 automate remote 474a
I purchased a automate 474K remote from Autozone and the instructions were to find a single button under the dash and set the new remote to the old settings. There is no single button, as far as I can see. But there is a large 2 x 3" wiring block where the antenae wire plugs into. There are many other wires also plugged into this "Automate" block. But no button.
What do I do ?
Feb 24, 2012 | Televison & Video
I have Partner mail VS release 5. When someone calls in they get the receptionist voice mail(10) instead of the day menu prompt of the automated attendant. How do I get messages to go to the automated...
I'm guessing that you changed the setting in the line coverage ext program (#208) or group call distrib (#206). Make sure that the settings for the lines are set to 1-assigned and not 3-VMS cover in program #206. In #208 there should be no data entered for the line if its not set up as a private line.
Jun 17, 2010 | Avaya Lucent Partner 616 Phone
How do I program some phone lines for immediate ring and others for a delayed ring? Also, how do I program the phone to answer with an automated message that says if you want marketing press 1, ifyou want...
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
as to the automated message, Does your system have a messaging card in it? If so what kind?
Aug 28, 2009 | Lucent PARTNER18 Corded Phone
Unable to check my mail
Are you using google or yahoo? Google is blocking many that use automated programs.
"Don’t use unauthorized computer programs to submit pages, check rankings, etc. Such programs consume computing resources and violate our Terms of Service. Google does not recommend the use of products such as WebPosition Gold™ that send automatic or programmatic queries to Google." I suggest that you don't use the automated programs with the same computer you are checking your mail with. http://www.fixya.com/support/t1868478-unable_check_mail where as yahoo only does sometimes
Mar 26, 2009 | Intel Motherboard
CD's used to record on The RCA CDRW 120 RECORDER that is compatible with my computer for the Automation System.
You are finalizing the CD after recording? After finalization they should play in all but very old CD players.
Jan 12, 2008 | RCA CDRW120 2-Disc CD Recorder
Automate AM6.2 Logo
63 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
