Question about Garden
Starts and runs at idle speed but dies when applying fuel, will run only about a minute or so with choke pulled out then dies.
  • 9 Answers
SOURCE: Poulon Wildthing 18" Gas Chain Saw
Some Poulans vent thru a fuel line going from the tank to the carburetor. Some vent thru the cap but eventually the duck bill valve starts leaking fuel. Then I suspect some people change that cap to one without a vent, which causes the problem you are describing.
Posted on Oct 26, 2008
steve_lima
  • 181 Answers
SOURCE: Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Posted on Feb 23, 2009
SOURCE: engine on my 04 sportsman 400 wo'nt idle unlesss
there is an electronic position sensor in the throttle housing and if the throttle cable sticks even a little the sensor interrupts the flow of electricity and disables the engine to prevent loss of control so chase down your cable and lubricate it and make sure you have full range of movement
Posted on Apr 03, 2009
finish line
  • 207 Answers
SOURCE: 97 Virago 1100 will start and idle. No highway speed.
sounds like you have trash in your carbs u need to take bottoms off and run a piece of a wire wheel through the jets
Posted on Jun 23, 2009
nobby63
  • 10 Answers
SOURCE: chainsaw wont stay running
check crankshaft seals,maybe sucking air. most of the time the seal on the starter side. hope this helps.
Posted on Jul 09, 2009
Won't stay running, runs for about two minutes then chokes and stops. Fuel tank is full it has oil also.
Hi, Clive the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture ***** improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. Gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
70cc motorcycle start and then dies
My motorcycle died while riding After it cranks but doesn turn over Why
Engine starts runs for 5 min then dies Sportbikes net
Runs for 20 Minutes Then Sputters and Stops
Apr 08, 2016 | Tank Motorcycles
Ryobi 9600 backpack blower. Starts great. Set to run, continues running. Upon attempt to use throttle, engine dies. Acts like choking out but removed carb cover an choke is no closing.
this sounds strangely like the high speed jet/pathway in the carb is clogged up with something ,
the best way to fix it is dissasmbly and cleaning of carb in solvent , but ive also had some limited sucess in past of using car fuel cleaner (says on bottle "cleans as you drive") too
Mar 09, 2015 | Ryobi Garden
It starts full choke ok,put to 1/2 choke run ok, but when l turn choke to off-run position it starts to die and backfires through the muffler.I drain the fuel tank. I drained the fuel bowel,clean the...
It's running lean, Richen up the idle mixture screw or pull the carby of and make sure the passages are not blocked. Also check that there is not a air leak between the carb and head.
Mar 04, 2015 | Garden
Fuel problems
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Re Bike will not idle with out choke Road Star Forum Yamaha Road Star
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
http://www.yamahaventure.nl/pdf/ownersmanualxvz13tf.pdf
Apr 23, 2014 | 2008 Yamaha Royal Star Venture
Engine dies when throttle applied
Hi, Tim the following applies to carbureted also fuel injected models and the usual suspects are:
9. Air/fuel mixture screw improperly adjusted.
13. The gas cap is not venting properly or fuel tank venting system blocked.
http://www.starbikeforums.com/forums/49-v-star/68346-650-starts-but-dies-throttle.html
https://yamahaclub.com/forums/topic/15251-idles-fine-but-dies-upon-throttle
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
May 12, 2013 | 2007 Yamaha V Star 1100 Classic
I have a Briggs & Stratton 2 cylinder motor Model # 42A707-125201. Runs fine at high speed with the choke off, but it will not idle smoothly unless the choke is partially on (about 2/3). I rebuilt...
The fact the choke must be 2/3 applied to obtain a smooth idle indicates not enough fuel is being supplied by the carb at idle speed. Applying the choke richens the air/fuel ratio.
I suggest you revisit the carb idle air/fuel jets, air passages and any adjustments as well as checking for intake air leaks.
Sep 15, 2017 | Yard Machines MTD Gold 185 HP Lawn Tractor...
Have a 90 f-250 5.8 gas burner. sat in a warehouse for 2 years. new battery and gas. starts and idles great. run up rpms for 2 minutes and it starts choking out. let off fuel and goes back to idling...
Carburetta is fouled. Run fine on choke - rich mixture. As it warms up and choke pulls off, its starving for gas.
First try adding fuel system cleaner to the gas tank. Do NOT go overboard. No more than double the recommended mix ratio.
The alternative is to remove the carb, open the bowl and spray out the jets and venturi with carb cleaner.
Its possible you may help it by removing the air filter and spraying every orifice you find on top of the carb. With carb cleaner. Be very carefull not to flood, pool carb cleaner in intake as this is not healthy for engine either. You can do this with engine running, so as not to pool, but slowly is best, both in engine speed and volume of carb cleaner.
Jun 22, 2011 | 1990 Ford F250
My chainsaw starts with choke when choke is off and i press trigger it just dies like its getting no fuel
Check the fuel filter, muffler, and air cleaner for plugging. Check the condition of the fuel lines for hardness, splitting, end rot, or kinking. Make sure the carburetor fasteners are tight. If no help, remove the lower carburetor chamber cover and examine the diaphragm and fuel metering valve that it controls. The diaphragm should not be hard, cracked or have any holes. The fuel valve has a rubber tip that may have deteriorated. If looks ok, then turn both L and H jet needles CW to stops (lightly), then back out CCW 1-1/2 turns each. Engine should start and run with these basic settings. Allow the engine to warm up, then pull the throttle full on. Adjust H needle CW until the engine speeds up somewhat, but is 4-stroking. Correct adjustment is when the engine continues to 4-stroke, but immediately 2-strokes when cutting. Allow to idle, and adjust L CW until the engine runs fairly well, but will allow the engine to 'follow the throttle'. Set idle speed screw so that the chain stops moving, but the engine continues to run. Hope this helps!
May 17, 2010 | Garden
Engine starts but dies when I pull throttle trigger
you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
Jul 22, 2009 | Ryobi Garden
Jun 22, 2009 | 1988 Yamaha XV 535 Virago DX
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
