F07 fagor 3fs 3611 - Washing Machines
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: fagor, washer dryer , model 2F-3611 flashing
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Hot point ariston aqualtis condenser dryer fault code f07
F07
Heater relay stuck
Check wiring
Check electronic control PCB
Jun 21, 2014 | Hoover Dryers
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
Need manual for fagor splendid
Here is the manual for the Fagor Splendid Pressure cooker!
http://www.hippressurecooking.com/fagor-splendid-pressure-cooker-manual/
Jan 13, 2013 | Fagor Elite/splendid Helper Handle
Our fagor fwm714it washing machine door will not open after the cycle finishes or when turned off. the machine has been showing the error code F07 of late.
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 27, 2011 | Fagor Washing Machines
มีไอบีเอ็มแล็ปท็อป t21...
If you mean BIOS update for Lenovo Thinkpad T21, you may refer to this link.
Other means of BIOS update for it can be found here.
Oct 26, 2009 | Lenovo ThinkPad T21 2647 Notebook
Fagor, washer dryer , model 2F-3611 flashing code F07 can you tell me what this is please
Jun 12, 2009 | Washing Machines
Fagor cook top connection
Guy from Fagor said brown & blue go to black & red. White and ground together go to green & yellow. Hope he's right.
Apr 04, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Manual for a Fagor Washing Machine FUS 3611 IT
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Mar 17, 2009 | Washing Machines
KX FM 131 มีคำว่า paper jummed
 I HAVE A BROTHER FAX MACHINE.  I CAN NOT HOOK UP TO MY FAXES GOING OUT
Feb 15, 2009 | Panasonic KX-FM131 Fax
Fagor Dishwasher FI-48w Replacement Parts
Angelo,
We are the manufacturer; Fagor Commercial, Inc. We have a network of parts distributors for our products. contact us to provide you with the most convenient one for you.
305 779 0170 or 1-866 GO FAGOR
Thanks
Jul 04, 2008 | Fagor Dishwashers
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
