Question about RCA TruFlat 27F520T 27" TV
Sound but no picture
I have a tv that was dropped on the ground there is sound but there is no picture what should i do how can i fix this
  • 668 Answers
You could have a broken CRT neck, (very bad) and or a broken pc prints in the Horizonal circuit. If it is because of broken prints, the likely hood of repairing goes up. If it is the neck of the CRT you are not in luck. The only way to find out is to take the back off the unit and look. I would recommend a service professional to do any pc trace repair. If you see broken glass on the inside just reassemble the back on the unit and chalk it up to bad luck and but another set.
Good Luck,
Skyassoc
Posted on Jun 18, 2009
There is no sound from the tv, how do I turn on sound?
About 243,000,000 results (0.42 seconds) Search Results
    10 Ways To Fix A TV That Has A Picture But No Sound ...
    removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/
    Nov 14, 2013 - If your TV has a picture but no sound coming out of the speakers, thereare a few things you can easily check. ... See below for the best solutions to fix a TVwith no sound. ... Television Has No Sound Answer 1: Make sure TV is not muted.
    There is no sound or low volume coming from the TV ...
    https://us.en.kb.sony.com/.../there-is-no-sound-or-low-volume-coming-f...
    Aug 15, 2015 - There is no sound or low volume coming from the TV speakers. Article ID: ... Make sure no headphones are connected to the TV. Verify that the ...
    Picture But No Sound TV - Bright House Networks Support
    support.brighthouse.com/.../Picture-But-No-Soun...
    Bright House NetworksIf you have picture but no sound. Press to ... Ensure that the audio and video cables are connected to the same inputs on the TV. For example, if ... My BHN App.
    No sound from my TV via HDMI when my cable box is ...
Jan 21, 2016 | Televison & Video
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
My magnavox tv has sound but only a white line
You have a bad ground or even a bad vertical IC. Have a tv tech pull the board out and inspect. It could be bad grounds and resoldering them may restore the picture. Also remember to check all capacitors in the immediate area of this IC, bad caps will heat up the vertical IC, and cause bad grounds. Replace the caps and Vertical IC as needed. Should be a standard fix in this case. Thanks for asking!
Apr 25, 2010 | Televison & Video
No picture but has sound
Coil L14401 is not making a good ground. Remove him carefully, scrape the ends clean and the board where he was removed. Now reinsert and resolder this little guy,and Bingo you have your TV back. This is a common problem with your TV! Thanks for asking!
Jan 30, 2010 | RCA F27442 27" TV
Standby light flashing red w/ no picture, but sound is ok
You have to find someone to resolder your vertical IC and have them examine it for any and all bad grounds. Should be able to watch tv soon!!!
Sep 24, 2009 | Sony KV-32S26 32" TV
I have a GE TV model: 27GT271 and no sound
Possible cause of the problrm is bad/poor solder on the grounds for the tuner circuit shield an the bottom (solder side) of the circuit board. Grounds need a wire jumper from point to point. This was a common problem for those sets and ocassionally it would take out the eeprom chip with it. (Various other problems were shrinking picture/fuzzy picture and intermitt. power)
May 14, 2009 | GE 27GT271 TV
Projection tv no picture has sound no picture
Try resoldering the vertical output IC. The crts may be blanking due to vertical deflection dropping out.
Apr 25, 2008 | Hitachi 50UX57B 50" Rear Projection...
Suddenly, Sound But No Picture
that is not and easy problem U need experienced tech to take a look at your TV call a local TV shop
Apr 17, 2008 | Mitsubishi WS-55805 55" Rear Projection...
RCA TruFlat  27F520T 27" TV Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
