Question about Weather King 10AJA2501AH Air Conditioner
Air keeps kicking off and on
The control pannel in side keeps clicking its a goodman
    Sergeant:
  • 340 Answers
Could be the fan motor ,wheel or relay chater you need service. Tom
Posted on Jun 18, 2009
Need to know the location of suspension switch to 2006 lincoln navigator.
The air bag suspension switch is located in the front passenger kick pannel. Use a light and get down where the front passengers feet go you will see a little red switch farther forward on the right hand side against the outside pannel.
Dec 06, 2010 | 2006 Lincoln Navigator
Contact points on compreessor motor are sticking closed and unit (compressor) does not kick on. No breakers are kicked, when I cycle them the contacts keep locking closed and compressor remains off.
Contacts are bad need new contactor. This happens often, Check out very carefully to see why contacts are going bad. May need new capacitor.
If you have voltmeter check the compressor side of the contactor to see if you have voltage. Rus
Jul 18, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman heatpump. Crazy pressure in heat mode
Check the TXV valve on the outdoor unit, it could be stuck closed. We have been experiencing the same problems with the 410 systems and the TXV was the culprit. Good Luck
Dec 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Blower works but no heat
If in fact you have the above listed furnace, you do not have a pilot but electronic ignition. You will need to remove the front cover on the furnace, tape down the door safety switch and then have someone help you by turning up your thermostat to a very high setting. Watch and listen inside the furnace. There should be some blinking going on at the control board followed by a small blower fan starting up. Then after 10-15 seconds there should be a click followed by an orange glow viewed thru the viewing window to the burner section. In a few seconds the gas valve should click and the burners will ignite. There is a safety switch that will sense flame and then keep the gas going to the burners. If it does not sense it, it will shut it off within 10 seconds. If all is well so far, your blower will turn on in about 90 seconds after flame. There is a diagnostic code chart on the back side of the access door if you get an error code (blinking) on the control board.
Always check little things like air filter, condensate drain and broken or loose wires.
Nov 05, 2008 | Goodman GMS90703BXA Heater
Weather King 10AJA2501AH Air Conditioner Logo
41 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
