Question about Roper RAS8445KQ Top Load Washer
Timer stuck on cycle will work if manually moved
My washer gets stuck on the cycle. I can manually turn the timer to each of the cycles and it will run the cycle, I have to guess how long to leave on each cycle an than move it to the next. Any suggestions why the timer wont automatically move?
Thank you for your help
  • 2 more comments
  • Crofton Feb 07, 2008
    The timer won't work on the machine. It gets stuck on each cycle. Help, my washer washed my clothes all night long and ruined them!
  • justallen919 Aug 28, 2008
    i believe the timer one the washing machine is there a way i can repair it myself and is it very hard. i would like to know where it is located.
    how much will a timer cost, and where it is located on the machine?
  • Anonymous Aug 31, 2008
  • 27 Answers
The timer has a small motor that advances it through the cycles. It either works or it's DOA. unfortunately you probably have to replace the timer complete.
Posted on Nov 01, 2007
My washer gets stuck on a cycle
if you can manually move the timer to the next cycle and all works fine then you have a bad timer on unit... there are sevral gears in the timer usually made of plastic and over time thaey can get worn and not allow the timer to advance... if all works when you move the timer then most likely this is your problem (the timer) good luck to you
Jan 13, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Cycle dial doesn't advance automatically anymore. I saw some listed problems that sounded similar, but not exact. Washer will work in all cycles, but only when I watch and move the dial manually.
Hello & Welcome to FixYa
Its seems that the Timer is stuck, as everything else is working fine in the unit and the dial ust gets stuck and so won't complete the cycle so the problem is with the Timer motor going bad and needs replacement. Please get back to me if you have any other questions.
Dec 24, 2010 | Kenmore 15522 Built-in Dishwasher
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
STICKS on cycle, wash, etc. If manually moved
Do you mean the timer or control dial sticks. If so then it may be the timer mechanism itself.
Make sure that when you are skipping a turn on the timer that the machine is actually performing that particular task of the cycle. For example if the timer gets stuck before the drain cycle, and you manually skip forward to it, that it actually drains the water out.
If so then it is most likely a worn timer mechanism which sticks.
Oct 23, 2009 | Frigidaire Dishwashers
My washer gets stuck on wash cycle...
I would replace the timer . Pt # 3954071 . If the model number above your thread is correct .
Sep 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not go into spin cycle but will spin if manually move the timer to another spin cycle
timer bust new timer or new machine, try getting someone to take a look at the timer first could be dirt stopping it from turning
Jun 30, 2009 | Maytag LAT3600A Top Load Washer
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
Asko w6221 front load washer stops after wash cycle
Do all of your cycles work when you turn them manually? If one cycle does not work when you turn the dial on it then it will be your timer (The dial assembly $100-up) If all your cycles work manually, then it could be your timer motor which is attached to your timer assembly. If you turn the dial pass the wash, on to the rinse, does the dial automaticly move (when finishng the rinse cycle)to the spin cycle? If so then your timer motor is ok. The only wires close to the bottom are the motor, but these should be high enough out of the way.
Apr 01, 2007 | Asko W6221 Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
323 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
