Question about GE JKP86 Electric Double Oven
Where is the control panel located on a JKP86-27" Double Wall Oven
heatman101
  • 43501 Answers
SOURCE: ge jtp48 double wall oven controls wont work after
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
heatman101
Posted on Apr 26, 2010
  • 277 Answers
SOURCE: double oven control panel just quit after power surge.
This is unfortunate.
The display is a computer you need to do most of the work.
Go Onlne to www.partselect.com and order that display. You will need a friend or a service guy to open and install you new display
Posted on Jul 26, 2010
ginko
  • 19396 Answers
SOURCE: i have a ge double
Hi.
Check the thermal cutoff. Remove the thermal breaker from the oven and use a multimeter set on Ohms to test it. If the part reads open (infinity of Ohms, same as on air), then you need to replace the breaker
Here the part:BREAK THERML
The part is indicated with number 353 in diagram below.
If the thermal breaker is OK it will read zero Ohms or very low impedance. In that case the next part to replace is the thermostat. The thermostat also called temperature sensor or probe, is located inside the oven cavity.Test the thermostat in a similar way to what you did with the breaker. If the thermostat is open at room, then replace it.
Here the part:Oven Sensor
The part is indicated with number 332 in diagram below.
Here the diagram. Click on the picture to enlarge:
Note. I could not locate the exact model number in database, please call the part seller and ensure that parts correspond to the ones used in your model.
Regards.
Ginko.
Posted on Dec 14, 2010
KevinWhite
  • 1902 Answers
SOURCE: !0 year old GE Profile
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Sorry for the bad news....but hope you understand. Please get back to me if you have any other questions.
Kevin
Posted on Jan 03, 2011
  • 59 Answers
SOURCE: Our monogram double wall oven
It's most likely that the error code you are seeing is F1, not F7. F1 is a code for 'stuck touch pad'. You will need to replace the clock/ERC or the touch pad (or both).
Posted on Feb 28, 2011
The top oven is over-heating with no change in temp display. A red-hot heating element on the left side of the oven (facing it) shows through the floor of the oven.
Good Morning Eileen, thank you for your inquiry!
I understand that your Electrolux double wall oven is having over heating issues. It is possible that this could be a faulty thermostat, control panel, or element. Since it could be anyone of these underlying having a technician out would help avoid any unnecessary part purchases. If you need help locating a technician you can visit your manufacturer's website for additional assistance with locating a technician. I hope this information is helpful to you. -Matt
Aug 09, 2015 | Electrolux 27" Built-In Double Electric...
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
How do i find the fuse location for a Wolf double oven, Model D030F/S ?
Dear Friend,
Pull the oven towards you, disconnect any electrical cord from the wall. Normally the fuse is located right next where the electrical cord enter in the back of the stove. If there is any panel right on top of where the electrical cords connects to the oven, simple removed that cover and there should be a fuse. If not, removed the rear panel where the electronic control panel is. Hope you can find it!
Good Luck!
Sep 20, 2014 | Wolf Range Ovens
WHIRLPOOL double wall oven has a blank control screen the start button is the only button that beeps
Their is a small in line fuse going to the oven control. Service manual
6b484ffa-e6f8-4c65-aa67-df87a903038a.pngPage 4-2 shows how to get to it. Radio shack has the fuses
Nov 24, 2013 | Ovens
Hi. All of a sudden neither the top or the bottom ovens will heat up, even tho electricity is getting to the control panel. What is the problem and what is the solution?
Your high limit thermostat is either tripped or blown. must remove unit from wall it is on the back wall of oven under panel. I would suggest having a professional look at it for you.
Jun 03, 2011 | Frigidaire 27 in. Electric Gallery Pro...
Do I have to pull the whole double oven assembly out of the wall to gain access to the upper oven power relay board? MCS230S
On some ovens you have to pull the oven out of the cavity and remove the top panel of the oven to get access to the electronic timer control. On other ovens you only have to remove the panel which is behind the timer without removing the whole thing. Just slide it out a bit and have a look at the panel behind the timer.
Feb 16, 2011 | Dacor MCS230SS Millennia Electric Double...
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Key board will not light up...Nothing....Oven light will come on......TTT
Whirlpool RBD305DQ15 Electric double wall oven, the control panel does not light up so you can't tell what you are doing. Do I need to replace the whole board or is there a fuse to replace?
Oct 05, 2009 | Whirlpool RBD305PD Electric Double Oven
Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Jun 13, 2008 | Kenmore 47732 / 47734 / 47739 Electric...
GE JKP86 Electric Double Oven Logo
56 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
